Author Topic: Cheap engines  (Read 2232 times)
Cheap engines
« on: October 16, 2012, 11:31:49 AM »
Purging some inventory of reman motors we have laying around...
price listed is COST and buyer would be responsbile for freight charges + 10%
PART #   APPLICATION   PRICE
129413   250 Chevrolet, 2 B.C. Integral Int. Manifold Four Pulse Air Holes In Head 1979-1985 L/B   $700.00
132910   3.3 Chrysler, Dodge, FWD. Caravan, Voyager, Mini Ran Van 1990-1992 L/B   $899.00
134413   3.9 Dodge, OHM, Roller Tappets 1992-2001 Magnum L/B   $800.00
184400   4.0 Ford OHM, Aerostar, Ranger, Explorer, 1990-1994 S/B   $500.00
196600   302 Ford, OHV E.F.I, Roller Tappets E,F,& U Series 1992-1993 S/B   $575.00
196713   302 Ford, OHV S.F.I. Roller Tappets, E,F,& U Series 1994-1996 L/B   $825.00
221100   2.2 Dodge, 2200cc OHC FWD W/O Roller Rockers, 8 Hole Crank Flange, 1986-1987 S/B   $420.00
321310   2.2 Chevy  4 Cyl, OHV F.I. Roller Tappets, Casting Numbers Must Match 1995-1998 L/B   $800.00
457110   2.6 Dodge, 2600cc, OHC RWD W/ Air Jet Valve Hyd. Valve Adj. Dakota, D-50, Raider, 1988-90 L/B   $950.00
306010   2.8 Chevy V6, FWD, M.F.I Flat Rear Cap, 1985-1986 L/B   $650.00
106513   252 Cadillac, 4.1, V6 W/O Detonation Sensor 1980-1982 L/B   $600.00
110513   4.1 Cadillac, V8 RWD, Lengthwise 3 Hole W/ Intake Manifold 1630558, 1619906, 1627320 1982-1986 L/B   $900.00
110613   4.1 Cadillac, V8 FWD Transverse Mount 6 Hole, W/ Intake 1631268 Tapered Venturi Throat on Intake 1985-1986 L/B   $900.00
120010   307 Chevrolet, 1968-1973 With Drilled Heads and Threaded Crank L/B   $575
120710   327 Chevrolet,  Drilled Heads, Crankshaft Threaded, 1968-1969 L/B   $725.00
125110   292 Chevrolet, 10, 20, & 30 Series 1973-1990 L/B   $695.00
126910   350 Chevrolet, T.B.I Flat Tappet 1987-1995 L/B   $625.00
127000   305 Chevrolet, 10, & 20 Series, Carb. W. Center Bolt Valve Covers, S/B   $500.00
129100   350 Chevrolet, 1968-1979  Left Hand Dip Stick, Two Piece Rear Main S/B   $500.00
132310   225 Chrysler, Dodge,  Cast Shaft, Mech. Lifters, Crankshaft Centering Ring is 2.157” 1975-1980 L/B   $595.00
140400   302 Ford, EFI, Dipstick In Block 1981-1985 S/B   $475.00
140800   302 Ford, 1979-1981, Dipstick tube in Block S/B   $475.00
141413   N/A,
142113   302 Ford, 1986-1991, EFI, Roller Tappets, Full Size Ford, Lincoln, Mercury L/B   $795.00
142810   351W Ford, 1969-1974 8 Intake Bolts L/B   $695.00
143010   400 Ford, 1971-1982 C-6 or FMX Trans., W/Code, PHB-AC L/B   $700.00
143613   351W Ford, 1978-1986 L/B   $695.00
144013   351M Ford, 1975-1981, L/B   $695.00
149410   2.3 Ford, 1989-1991, 2300cc, OHC, Roller Rockers, 8 Spark Plug Head L/B   $595.00
150610   3.0 Ford, 1986-1989, V6 Aerostar, Ranger, L/B   $795.00
152400   1.9 Ford, 1985-1986, Carbureted S/B   $350.00
152410   1.9 Ford, 1985-1986, Carbureted L/B   $595.00
159812   445 Int’l , 7.3 Liter (Ford Deisel), 1987-1993 F250-F600 L/B   $1,975.00
192210   2.0 Ford, FORD, 122 CID, 2.0L L4 - L/B 1987-1988 Flat Rear Cap, L/B   $595.00
194100   300 Ford, 1987-1995, F.I. S/B   $400.00
194310   300 Ford, 1981-1986, Dipstick Tube Screws in Block, L/B   $695.00
194400   300 Ford, 1981-1986, Dipstick Tube Screws in Block S/B   $400.00
194510   300 Ford,  1977-1982, Dipstick Screws into Oil Pan L/B   $695.00
194600   300 Ford, 1977-1982, Dipstick Screws into Oil Pan S/B   $400.00
195300   460 Ford, 1979-1988, E & F Series S/B   $500.00
196010   460 Ford, 1979-1988, E & F Series L/B   $895.00
196113   302 Ford, 1987-1992 Roller Tappets, EFI, Full Size Cars L/B   $895.00
197200   351W Ford, 1987-1993, E,F,& U Series, EFI Dipstick tube in Block S/B   $500.00
204100   4.0 Jeep, 1987-1990, Wrangler, Cherokee, Comanche, Wangoneer, S/B   $400.00
212113   307 Oldsmobile, 1985-1990 Vin “y”, Roller Tappets, Except 1985 442 L/B   $795.00
220330      $375.00
220300   318 Dodge, 1985-1989 Flat Tappet, S/B   $400.00
225610   360 Dodge, 1975-1989 All Trucks, & Vans, 14mm Spark Plugs L/B   $800.00
226200   318 Dodge, 1968-1984, Mtg, Bolt For Brace From Trans. Bell Housing 9” on Left Side From Rear Of Block, S/B   $500.00
300100   2.5 GM, 151 Chevrolet, 1977-1979 Monza, S/B   $375.00
300410   229 Chevrolet, 1980-1984 3.8 V6 L/B   $625.00
302600   305 Chevrolet, 1980-1985, Dished Pistons, 7 Bolt Holes in Head For Exhaust Manifold, S/B   $475.00
302610   305 Chevrolet, 1980-1985, Dished Pistons, 7 Bolt Holes in Head For Exhaust Manifold, L/B   $675.00
302910   GM, 151 CID, 2.5L L4 - L/B, 1990-1991, 2.5U Roller Tappets, Trigger Fire Ing. Chain drive, W/ Balance Assembly, Somerset, Regal   $845.00
303100   CHEVY, 366 CID, 6.0L V8 - S/B, 1968-1990, H.D. Timing Chain, W/O HEI Ign. S/B   $775.00
303110   CHEVY, 366 CID, 6.0L V8 - L/B, 1968-1990, H.D. Timing Chain, W/O HEI Ign. L/B   $1,500.00
303600   CHEVY, 427 CID, 7.0L V8 - S/B, 1968-1990, H.D. Timing Chain, W/O HEI Ign. S/B   $950.00
305010   GM 79-68 350CID, 5.7L V8 L/B   $650.00
305200   GM, 350 CID, 5.7L V8 - S/B. 1980-1985   $380.00
305210   GM, 350 CID, 5.7L V8 - L/B, 1980-1985   $600.00
305800   CHEVY, 350 CID, 5.7L V8 - S/B, 40,50,&, 60 Series With Air Brakes, 4 Bolt Mains   $550.00
309310   CHEVY, 454 CID, 7.4L V8 - L/B, 1973-1987, Truck Carb.   $1,000.00
309811   GM/Jeep,173 CID, 2.8L V6 - L/B, 1984, V6, Grooved Rear Cap   $595.00
310910   GM, 122 CID, 2.0L L4 - L/B, 1987-1989, OHV, Trigger Fire Ign. W/ Dual Line For Fuel Pump Cut Off   $600.00
311501   GM, 173 CID, 2.8L V6 - S/B, 1985-1987, V6 RWD Grooved Rear Cap   $385.00
311511   GM, 173 CID, 2.8L V6 - L/B, 1985-1987, V6 RWD Grooved Rear Cap   $600.00
311601   GM, 173 CID, 2.8L V6 - S/B, 1988-1989, V6 RWD grooved Rear Cap   $385.00
311611   GM, 173 CID, 2.8L V6 - L/B, 1988-1989, V6 RWD grooved Rear Cap   $650.00
312010   GM, 173 CID, 2.8L V6 - L/B, 1987-1989, V6 FWD, Flat Tappet, Alum. Heads, Trigger Fire Ign.   $650.00
312110   GM, 173 CID, 2.8L V6 - L/B, 1987-1989, V6 FWD Flat Tappet, Alum. Heads, Trigger Fire Ign. W/ Fuel Pump Cut Off Switch   $650.00
313500   GM, 262 CID, 4.3L V6 - S/B, 1988-1991, Roller, W/O Detonation Sensor   $535.00
313510   GM, 262 CID, 4.3L V6 - L/B, 1988-1991, Roller, W/O Detonation Sensor   $800.00
313610   GM, 262 CID, 4.3L V6 - L/B, 1988-1991 Roller, W/Detonation Sensor In Bell housing Flange   $875.00
   ALL ENGINES ARE AS IS " NO WARRANTY"!!!
   ALL SALES ARE FINAL!!!
Re: Cheap engines
« Reply #1 on: October 16, 2012, 11:37:29 AM »
is that the V6 longblock that would fit in sarahs mj?
Re: Cheap engines
« Reply #2 on: October 16, 2012, 11:38:48 AM »
yes.. I saw that..
there is also  renix SB...
the renix motors have more nickle in them are are better blocks than the later HO 4.0L
awl4928
Re: Cheap engines
« Reply #3 on: October 16, 2012, 01:45:01 PM »
Just saw this on my phone need to read though this thoroughly.  That engine Smike on craigslist and the Colorado you have all are of interest
