Author Topic: Ford 8.8 4.10 gears or deeper...  (Read 2619 times)
« on: September 24, 2012, 11:18:22 AM »
just throwing it out there...
wouldnt mind throwing something a bit stronger in the MJ...
dont even bring up tons...
4.5 x 5 bolt pattern needed...
looking for a XJ ro MJ D44... but those are like hens teeth...
Re: Ford 8.8 4.10 gears or deeper...
« Reply #1 on: September 24, 2012, 11:26:33 AM »
quick search on RC found these
$80 XJ 44 housing-> http://www.rc4x4.org/rcforum/index.php?topic=17810.0
$1200 xj axles - dana 30/44 4.88, locker in rear -> http://www.rc4x4.org/rcforum/index.php?topic=16531.0
« Reply #2 on: September 24, 2012, 11:42:32 AM »
matt was throwing the idea of decommishioning the YJ and throwing the 35 back under it.  built 8.8  4.10's all Nuway parts
« Reply #3 on: September 28, 2012, 11:45:48 AM »
any more thought about the 8.8?
« Reply #4 on: September 29, 2012, 10:19:58 AM »
Interesting reply I got from a friend when asking about a rear for the MJ...
"8.25 29 spline with KJ disc brakes. Easily available with 4.10s. An early Liberty axle is perfect size, just more brackets to remove, but will already have the disc brakes.
Cheap and plenty strong. No c-clips, perfect width. No carrier break when regearing. Small housing offers good clearance. No draw backs compared to an XJ/MJ 44, except they need a good cover - but they all need a good cover anyway...."
Seen anything at the yard?
« Reply #5 on: September 29, 2012, 12:11:59 PM »
Liberties are still pretty new. Don't think I've seen one at J&J.
« Reply #6 on: September 29, 2012, 12:50:16 PM »
No way Jose
« Reply #7 on: September 29, 2012, 01:09:05 PM »
What's the bolt pattern on a liberty?
« Reply #8 on: September 29, 2012, 01:43:55 PM »
same as XJ....
Callelle
« Reply #9 on: September 29, 2012, 04:51:50 PM »
Why go for specifically a KJ's 8.25? You can get a 29 spline out of any 97 or later XJ that doesn't have ABS. If you pull one for a 4 cylinder, it should already have 4.10s in it. The only real difference is that that XJ's has drums and is already set up for leaf springs. There are a few draw backs to the 8.25 vs the 44. 8.25s do have C-clips and the housing hangs down a good bit due to the large lip on the bottom of it (though this can be ground or cut off). Strength wise, the 8.25 and D44 are just about equal.
« Last Edit: September 29, 2012, 04:53:33 PM by Callelle »
« Reply #10 on: September 29, 2012, 06:42:36 PM »
« Reply #11 on: September 29, 2012, 09:26:32 PM »
I didn't know they'd gone C-clipless. I wonder how they did that. XJ and Dakota/Durango 8.25s definitely have C-clips.
Callelle
« Reply #12 on: September 29, 2012, 10:36:10 PM »
They didn't. KJs have C-Clips. All 8.25s have C-Clips. I don't know about the over all housing size, but the 8.25 has less ground clearance than a 44, mainly due to the bottom lip (some of which can be alleviated by shaving some of the bottom off)  The only advantage that using one off of a KJ would be the disc brakes already on it. You can do a disc brake swap onto an XJs 8.25 either by using the parts from a KJ or a ZJ. 4.10 gears come standard in 4 cylinder XJs.
« Last Edit: September 29, 2012, 10:38:27 PM by Callelle »
« Reply #13 on: October 18, 2012, 07:16:45 PM »
I'm back to this...
Anybody?
« Reply #14 on: October 18, 2012, 08:20:36 PM »
Look on rc4x4 always seems to be some on there
« Last Edit: October 18, 2012, 08:22:37 PM by cracker »
