Author Topic: YJ brake booster & master cylinder  (Read 1854 times)
FallibleXJ
« on: September 10, 2012, 09:20:21 AM »
Hey folks,
After wheeling this weekend it became blatantly clear that the brakes on my old CJ are terrible. I am looking for the master cylinder and brake booster from a later model YJ to swap into it.
Re: YJ brake booster & master cylinder
« Reply #1 on: September 10, 2012, 09:43:33 AM »
you want 73-74 corvette MC, its 20$ at any white box store, 5$ core.
you will need to adapt from 3/16" hardline on the jeep to whatever the two sizes on the vet MC are, and you may need to shorten the push rod like on early years.
« Reply #2 on: September 10, 2012, 09:44:18 AM »
o and your real problem is mud filled 4 wheel drums become 20% brakes until they dry out haha
« Reply #3 on: September 10, 2012, 10:41:35 AM »
swap to disks in the front and you will notice night and day difference
FallibleXJ
« Reply #4 on: September 10, 2012, 12:30:31 PM »
I saw that when I was researching, but I also saw people using the YJ parts. I figured the YJ conversion may be easier to track down parts for. And what do you mean by a 'white box store'?
That costs quite a bit more money
« Reply #5 on: September 10, 2012, 12:37:52 PM »
white box just means unbranded autoparts...
not as expensive as you might think..
http://www.jpmagazine.com/techarticles/drivetrain/154_0704_early_jeep_disk_brake_conversion/
or you can always swap the front end for a later CJ
« Reply #7 on: September 10, 2012, 12:42:39 PM »
paul and i both did disk swaps.
we swapped from the Knuckles out from doner axles.
should try to get some 297 joints in there also, since those 267's will snap pretty easy.
