Author Topic: damnable fuel lines  (Read 19540 times)
damnable fuel lines
« on: June 26, 2012, 04:07:52 PM »
So it looks like #6 lasted me some 2 months/ 6,000 miles.
Seriously? That's worse than the coated crack-prone lines. It was a MUCH smaller failure though.  Pinhole that wasn't big enough to even pulse with injection. But a failure nonetheless.
Re: damnable fuel lines
« Reply #1 on: June 26, 2012, 04:16:26 PM »
sender is over at scotty's...
« Reply #2 on: June 26, 2012, 05:06:10 PM »
gracias!
damnable fuel lines
« Reply #3 on: June 27, 2012, 12:19:31 AM »
Motherfucking sending unit doesn't fucking work. Fuck fuck fuckity fucking fuck.
« Reply #4 on: June 27, 2012, 12:47:53 AM »
after 2 hours of bs you took a half hour to replace this thing,
damnable fuel lines
« Reply #5 on: June 27, 2012, 01:38:16 AM »
That's in smikey drink time. Was at least an hour.
Assuming I don't knock over my blocking and drop the tank and spill 10 gallons of fuel, next time should be half an hour.
« Reply #6 on: June 27, 2012, 08:15:34 AM »
sending unit or your idea?
damnable fuel lines
« Reply #7 on: June 27, 2012, 09:49:36 AM »
Actual fuel level sender.
Need to investigate further - make sure connector pinout matches; no pinched wires between tank and frame; etc.
Worst comes to worst I should be able to swap the new fuel line fittings into the old module and at least not worry about that rotten rustiness.
damnable fuel lines
« Reply #8 on: June 27, 2012, 08:03:22 PM »
Appears to have been installer error. Was clocked wrong w float pinned against tank wall. Heard a 'sploosh' as I turned it. Reading just under 1/4 now. Reinstalling. And motherfuckering myself.
« Reply #9 on: June 27, 2012, 08:09:55 PM »
noice
damnable fuel lines
« Reply #10 on: June 27, 2012, 09:13:56 PM »
Left valve open for a while. Level didn't move. Motherfucking myself :-(
damnable fuel lines
« Reply #11 on: June 27, 2012, 10:11:53 PM »
Definitely worse off than before unless it frees up driving tomorrow.
Sitting at about 3/16 on the gauge, and I can see fuel in the filler neck. On the bright side the fill valve stopped fuel flow where it should have. That has nothing to do w my changes though. My changes were in response to leaking when it doesn't stop flow.
I shut the valve before I came in. I don't trust any of it.
« Reply #12 on: June 27, 2012, 11:07:54 PM »
so did you or paul break my 1/2" ratchet last night?  id like a new one please :)
damnable fuel lines
« Reply #13 on: June 28, 2012, 12:07:58 AM »
I'd speak with the fine thread nuts on coarse thread bolts guy. I used no ratchets.
carchameleon
« Reply #14 on: June 28, 2012, 12:38:04 AM »
when i pulled it off your tool board & asked what you did to it
just take it back to sears & get a new one
