Author Topic: 572  (Read 413132 times)
SlvrJK
  • Full Member
Re: 572
« Reply #870 on: March 23, 2014, 01:28:08 AM »
Looks good man
Re: 572
« Reply #871 on: March 24, 2014, 10:00:24 AM »
well, the welds look good anyway  :o
not much to support the front bumper. Solo cup fabrication was in full accueyeball effect
Re: 572
« Reply #872 on: March 24, 2014, 10:38:35 AM »
solo cup...level...close enough
tony
  • Come and take it
Re: 572
« Reply #873 on: March 24, 2014, 01:12:38 PM »
nice
SlvrJK
  • Full Member
Re: 572
« Reply #874 on: March 24, 2014, 04:27:16 PM »
Lol nothing wrong with that.
Re: 572
« Reply #875 on: March 26, 2014, 10:51:31 AM »
Battery enclosure violation
rear firewall additions
electrical and oil lines in cab
trans NSS
trans blow proof covers
orbital is not behind firewall
number plates
Re: 572
« Reply #876 on: March 26, 2014, 11:35:47 AM »
went after a leaky 14bolt spindle last night.  the seal surface has been pitted and grooved beyond used.  Disassembled, cleaned and sanded down.  pressed on a speedy sleeve repair kit, installed new timken seal in hub.  spent more time cleaning gear oil dirt soaked brake components that install took.   hopping to fix leaks!
Re: 572
« Reply #877 on: March 27, 2014, 07:57:23 AM »
trans NSS
number plates
Trans blow proof cover?
What I read was orbital needed to be "behind Cowl"
I assumed that meant under.
I was hoping to just encase it in its own aluminum box under the cowl if it's an issue.
Re: 572
« Reply #878 on: March 27, 2014, 09:04:44 AM »
Enclosure of the orbital would at least meet the spirit of the rule, very much so. The intent is that a bad fitting/ loose fitting/ blown line won't douse you w burninating hot fluid or pose an injection hazard.
Re: 572
« Reply #879 on: March 27, 2014, 02:23:29 PM »
Re: 572
« Reply #880 on: March 27, 2014, 04:07:36 PM »
That's kinda gross
Re: 572
« Reply #881 on: April 01, 2014, 01:50:08 PM »
new helmet and pumper ordered.
Re: 572
« Reply #882 on: April 05, 2014, 11:29:52 PM »
pumper mounted
rear interior tin fab'd and installed
weighs 4960 race packed full of fuel me not in it  :o
SlvrJK
  • Full Member
Re: 572
« Reply #883 on: April 06, 2014, 05:44:06 AM »
Jeebus, I would have thought it would be lighter than that.
Re: 572
« Reply #884 on: April 06, 2014, 07:40:57 AM »
x2
That's pretty portly!
