Author Topic: 572  (Read 413459 times)
Re: 572
« Reply #780 on: December 08, 2013, 07:24:47 PM »
I think mike's application falls out of the suggested guidelines for indestructible.
Good point.
Re: 572
« Reply #781 on: December 08, 2013, 08:48:26 PM »
But I won't say anything.
plenty of guys on 44's that dont brake those.  And with way more HP.
 I would think the pinion at the yoke would have broke first.   Or maybe the 1350 joint at the axle end.
I think he got a defective one.
Re: 572
« Reply #782 on: December 08, 2013, 09:01:48 PM »
Re: 572
« Reply #783 on: December 08, 2013, 10:24:01 PM »
I'd tend to agree. And also agreed on what the weak points SHOULD be, much further up the chain from the axles shafts.
Re: 572
« Reply #784 on: December 09, 2013, 08:33:22 AM »
Same I was sure it had to be the spider gear welds. Upgrade to 300m doesn't sound like a bad idea though. Might try and get a spool with that upgrade?
Re: 572
« Reply #785 on: December 09, 2013, 09:24:07 AM »
i was surprised i was able to use 2 telescoping magnates and with some jiggling the chunk of spline slid out of the carrier though the tube.  Carrier does not appear to be f'd just the seal.  I didn't pull the diff cause no point in 2x work.  it got a spindle and hub thrown back on and stuck in the trailer.
Ill look at spool costs.  id say the weak link is still the stock rusty front 84 GMC drive shaft with one semi dry original 1350 ujoint that was in said drive shaft when i picked it up out of the scrap pile lol.  it is 5.38 times less ass there and really only 300hp on a cold day.  A ring gear running backwards or the shafts still have to be the weak link.
300M and maybe a spool will be the fix.  needed a fluid change and a diff cover bolt guard is near in the future
for what i have done with KRTs in the rocks, i dont think it was defective.  anger and HP could not break them at least 2X
Re: 572
« Reply #787 on: December 09, 2013, 09:34:25 AM »
RCVs now for rockwell 2.5 tons
47 spline    :o
Re: 572
« Reply #788 on: December 09, 2013, 10:06:29 AM »
237 for a yukon 4.56 and up isnt terible.  would get rid of the spacer i have now.
Re: 572
« Reply #789 on: December 09, 2013, 10:34:08 AM »
email into RCV.
their live chat is not so live.
probably have a 4130 shaft warrantied- either sell the set or keep as spare.  Then just get another full 300M set because no sense in having 3 spare weak shafts.
Re: 572
« Reply #790 on: December 09, 2013, 01:21:40 PM »
any more air videos of 572 haha.  thats a fun rock jump hill
i like the one josh got of 4 wheel roosts though two gears launch
Re: 572
« Reply #791 on: December 09, 2013, 01:28:05 PM »
that ledge looks so small on video
Re: 572
« Reply #792 on: December 09, 2013, 01:48:45 PM »
its only like 4'  :)
Re: 572
« Reply #793 on: December 10, 2013, 12:48:26 PM »
Called RCV- they said it broke the way they break.
287$ option to upgrade the shaft to 300M, or free warranty of the 4130 shaft.
the upgraded 300M kit has 300M CV's so ill just warranty the shaft, and get another full set of 300M RCVs.
he was very supprised to hear 300hp and 44" tires broke a shaft.  same response copper fab gave me when i was the only guy to break one of there sway bars so far.  Cant wait to break a solid knuckle next!
Re: 572
« Reply #794 on: December 10, 2013, 12:50:04 PM »
RCV Performance Products
611 Beacon Street
Loves Park, IL 61111
Phone: 815.877.7473
Fax: 815.877.1218
sales@rcvperformance.com
RMA 121013AKWR
Craig
