Author Topic: 572  (Read 413145 times)
Re: 572
« Reply #630 on: August 16, 2013, 01:59:29 PM »
they figured out how to cam away EGR on this gen also.
If it's a static cam, that's got to be bad for it in tuned form in my mind. Unless they did away with the need for it entirely on the tuning side
orange anchor
Re: 572
« Reply #631 on: August 16, 2013, 02:41:57 PM »
is it ready for testing at Lake X?
Re: 572
« Reply #632 on: August 16, 2013, 04:10:09 PM »
will be ready one way or another tonight!  i want a full speed rip before dark on M4 grounds!
Re: 572
« Reply #633 on: August 17, 2013, 01:31:11 AM »
fully preped and beat on around M4.  Fucking thing leaks anywhere gear oil is so that will have to be delt with next week.
Roof on and coolers doing jobs.  shocks and bumps charged ready for some shakedown.
Re: 572
« Reply #634 on: August 17, 2013, 01:14:31 PM »
I am next door at Ontario County park and could hear the sweat sounds for a while.. Then it got quiet.. Hope all is fine.
Re: 572
« Reply #635 on: August 17, 2013, 02:50:01 PM »
All is well just a leaky brake booster.  Good test run
Re: 572
« Reply #636 on: August 17, 2013, 02:53:48 PM »
This thing is sweat!
Sounds awesome on the rev limiter.... ;D
Re: 572
« Reply #637 on: August 18, 2013, 12:25:38 AM »
needs more brakes
rear 14 bolt needs wheel seals / vent added
front 60 needs inner axle seals
RCV boot clearance issue  - i think the boot is rubbing on the king pin threads, weird.
needs expanded steel on the floor tin
tree bars
trans dip stick moved
bunch of other shit normal prep
Re: 572
« Reply #638 on: August 18, 2013, 04:36:29 PM »
Good stuff. Working most nights I'm guessing? Lmk.
Re: 572
« Reply #639 on: August 18, 2013, 11:04:45 PM »
Tony, Matt, Myself, and Another FLX guy went to Pines today to rip around.
Buggy rips hard, no issues still. trans seems to not care on near vertical climbs.  The deeper gear of the 4l60e and way better shift points along with the 5.38s make this thing feel like twice the power to the ground as the other car.  is pretty silly with your foot down.
Fixed the case leak last night, two pin holes in the PTO cover rotted out- swapped with an SM465 PTO cover i had laying in the shop.
Re: 572
« Reply #640 on: August 18, 2013, 11:37:39 PM »
i have decided not to race this weekend.   i am going to continue to prep the car, but i just dont want to rush it be cause it will stay hacked.
I still plan to take the car down Friday afternoon, prerun the course but wreck wheel the weekend.
Re: 572
« Reply #641 on: August 19, 2013, 07:40:57 AM »
 :( for racing, but probably the right thing to do.  Can't wait to see this thing in action!  8)
Re: 572
« Reply #642 on: August 19, 2013, 08:19:46 AM »
define wreck wheeling
Re: 572
« Reply #643 on: August 19, 2013, 08:20:43 AM »
Van Motor FTW...
are you sure you dont want a 6 popper...
Re: 572
« Reply #644 on: August 19, 2013, 09:09:56 AM »
Recreational wheeling, while attempting to find weak points (wreck the car off course)
