Author Topic: 572  (Read 413142 times)
Re: 572
« Reply #1560 on: May 21, 2017, 09:04:42 PM »
severe grinding on left side noted
motor running great but blowing hard smoke
lots of flogging this weekend and still functional/
Re: 572
« Reply #1561 on: May 25, 2017, 09:48:16 AM »
42" reds?
Re: 572
« Reply #1562 on: May 25, 2017, 09:53:45 AM »
42" reds would probably take care of that grinding noise.
Re: 572
« Reply #1563 on: May 25, 2017, 10:23:23 AM »
20"s will never happen so thats a no go
Re: 572
« Reply #1564 on: June 02, 2017, 11:02:51 AM »
front diff inspection performed last night.
gear set in great shape.
Put the girdle cover on Bret traded me.  not sure i like it- i don't have a set of pass through sockets to properly tighten carrier cap nuts.  also seems like it will be a one time use once the front gets smashed by rocks and becomes un serviceable.
brakes / hubs steering seems in good shape.  not sure what to occasional grinding noise is i was hearing.
Re: 572
« Reply #1565 on: June 02, 2017, 11:06:37 AM »
RCVs?  hahaha
Re: 572
« Reply #1566 on: June 02, 2017, 11:12:23 AM »
they sound HORRIBLE but thats not the sound im worried about.
probably should have done a complete hub tear down but didnt have time.  dont have spindle bearing parts on hand anyway.
Re: 572
« Reply #1567 on: June 02, 2017, 11:30:50 AM »
You might find this helpful. Link to the girdle cover installation guide
http://www.jantz4x4.com/jantz.php?p=manual&pro=girdle&mid=jgi
Quote
Install four non-locking ½ x13 nuts, 80 ft lbs. I made a ¾ socket with the back end hand ground like a spark plug socket drive to reach the nuts. You then drive this socket with another socket and torque wrench.
Re: 572
« Reply #1568 on: June 02, 2017, 11:31:57 AM »
or just weld two deep sockets together to accomplish same thing?
Re: 572
« Reply #1569 on: June 02, 2017, 11:33:30 AM »
You're not touching them because RCV will not warranty them until after they break completely?
Re: 572
« Reply #1570 on: June 02, 2017, 01:35:39 PM »
im sick of touching them and rebuilding them.
they are too expensive to maintain, i have broken 5 shafts including a carrier damage.  the splines are now so warn i have about a 80 degree difference of travel tire to tire.
planning to just run them till catrostrophic failure then sell the bits with the other 4340 set of RCVs i have.
Matts have ~500 miles on them and are starting to sound like mine.
Re: 572
« Reply #1571 on: June 09, 2017, 01:45:02 AM »
pulled out of trailer to hook up pumper and window net
found water pump dripping from shaft seal.  changed used spare from trailer.  leaking from back bolts.  ran to zone for a white box and changed that with success.  that was at 10:30.  Packed and prepped trailer, window net, pumper.  nothing else prepped meh.
Re: 572
« Reply #1572 on: June 11, 2017, 09:25:47 PM »
didnt really feel like killing tires so i was taking it easy.  got wacked after i pulled over for a siren just after the first check point.
half mile later the carnage spread to a 14bolt yoke, rear shaft, air bumb, chassis damage, and gouges in my fuel cell enclosure.
swapped sway bar links to trackbar location after a 2" difference fit was eyeballed, drove the car out in 2wd to the road and back to the property.
Re: 572
« Reply #1573 on: June 22, 2017, 12:04:29 AM »
back in shape minus two leaking diffs, a cracked chassis near rear three link mount, and tool bags are a mess.
new rear shaft installed
sway bar links installed
rear 14 bolt yoke changed
lube job
broken shaft rebuilt and assembled as a good spare
Re: 572
« Reply #1574 on: June 22, 2017, 01:55:14 PM »
Crack kills...
