Author Topic: 572  (Read 413444 times)
Re: 572
« Reply #1260 on: January 23, 2015, 11:46:09 AM »
probably for as long as i want them.  id like to be careful with them and keep them in the shop though.  Welcome to do it after koh.
Re: 572
« Reply #1261 on: January 23, 2015, 01:39:47 PM »
Sounds ideal, was hoping they'd be available after.
tony
  • Come and take it
Re: 572
« Reply #1262 on: January 23, 2015, 05:09:30 PM »
I'll lend a hand tomorrow around 1030 if your at m4 with final prep
Re: 572
« Reply #1263 on: January 23, 2015, 08:18:39 PM »
4420 lbs first weigh in.
Re: 572
« Reply #1264 on: January 24, 2015, 02:16:39 AM »
Side trans tin cover reduced to 1/16" and flat blacked
removed rear fire wall 16g steel, 1/16" alum replacement lighter and safer.  goes wider and too the floor
pumper torched out
Ligher bar and radio is 15 lbs
going to work on front foot well tins tomorrow, and swap to prerun tires to check weight again.
car was 4420 and less than 3% off set front to rear AND side to side.  weird.  guess cat scales were right.
Re: 572
« Reply #1265 on: January 24, 2015, 10:17:53 AM »
Awesome! Must be a load off knowing you're that close!
Re: 572
« Reply #1266 on: January 25, 2015, 01:45:41 AM »
last push list
mount harnesses
check window net
install seat
lock roof bolts down
wire light bar back to existing circuit
power to radio
mount GPS mount
install SPDT switch / circuit for front lights
rear number board
eval hood / hood paint
air cleaner tab
weigh car on race scales (God these scales are HEAVY!)
swap helmet sheild / clean helmet
in car water
first aid kit / food kit
pack tool bags
assemble fuel jugs
procure fire extinguishers
procure fuel tarps
pack totes
pit tent power assesment
remove alum box from 4500
sleeping 4500
4500 inspection
Call bank for VISA travel
Erik- i think im going to change the air filter gaurd to the bottom like you said.  such a simple thing that has stumped me- will fix easy removal, dust shield on bottom, and look way less obtrusive to the car lines.
weekend buy list
tarps
fire ext
black bed liner spray
ready to load
Re: 572
« Reply #1267 on: January 25, 2015, 09:12:20 AM »
I have a couple cases of epoxy chassis rattle cans If that's what your looking for
Re: 572
« Reply #1268 on: January 25, 2015, 09:49:30 AM »
all set.  interior and hood got flat black bedliner.  looks mint, low reflection for night
Re: 572
« Reply #1269 on: January 25, 2015, 10:30:51 AM »
looks awesome...
Re: 572
« Reply #1270 on: January 25, 2015, 01:59:37 PM »
Looks great!
Re: 572
« Reply #1271 on: January 25, 2015, 09:45:58 PM »
So when you're on the track and you encounter a point where you'd need to winch out, how do you do that when you have no codriver?
Re: 572
« Reply #1272 on: January 25, 2015, 10:09:45 PM »
You get out and do it.
Re: 572
« Reply #1273 on: January 26, 2015, 12:22:43 AM »
getting out sucks.  you loose 10 minutes plus what you had to do.  belts and nets and radios and pumper hose.  something is bound to get put back in an agitating way.
your car being in the way is also a risk, especially since i cant really see behind me.  at all.
Tonight start good, turned bad, returned to good.
pulled the rear bench seat from the 4500, made a carpet covered deck, mattress fits much better now.  Rear tool box removed.  Radio antenna mounted to headache.
Stripped out a rear wheel stud locking down lug nuts on the car.... added spare front / rear studs to the parts pile and spare lug nuts....
packed car tool bags and on board spare parts.
pumped out matts car.  11 gals of fuel is FUCKING heavy.
added back my remote fill to the car.  no way you guys would be able to fuel me safely without it.
packed and packed more.  Matt and I dropping 4500 at regional 8am for sticker.
Re: 572
« Reply #1274 on: January 26, 2015, 08:42:07 AM »
last push list
mount harnesses
check window net
install seat
power to radio
mount GPS mount
rear number board
air cleaner tab
in car water
pack tool bags
assemble fuel jugs
procure fuel tarps
pack totes
sleeping 4500
4500 inspection
weekend buy list
tarps
fire ext
headlamp
4500 radio power
footwear
spare 4500 key
fire suit
« Last Edit: January 26, 2015, 03:39:15 PM by M4wdFab »
