Classifieds
For Sale
Emglo portable air compressor
Pages: [
Topic: Emglo portable air compressor (Read 3312 times)
on:
May 29, 2012, 01:43:35 PM »
Branded as Jenny or Dewalt...
this is an orignal..
$450 OBO
K15A-8P 1.5 hp 8 Gallon Single Phase 115v or 230 Volt Electric Air Compressor Heavy-duty single stage cast iron compressor pump Made in Somerset, PA USA Splash lubricated Belt driven with a large flywheel for extra cooling and easier start-up Each unit is filled with Synthetic Blue Compressor Pump Oil Directional air shroud for reduced pump temperatures Totally enclosed heavy-duty belt guard 8 & 15 gallon tanks are low profile, powder coated twin tank receivers 17 and 30 gallon tanks are powder coated and ASME certified Convenient lifting handles Anti-vibration feet Pneumatic tire(s) Protectively mounted fittings Manual tank drain(s) Large canister intake filter with replaceable filter elements Special unloading valves to assist in motor starting Stainless steel braided discharge hose Tank gauge Regulator and outlet pressure gauge Pressure relief safety valve Designed, tested and proven to meet the demands of the construction and rental industry Electric Motor Constant run control set at 105-125 PSI High quality pilot valve Industrial/Commercial grade UL Listed electric motor Thermal overload motor protection 6 ft power cord Specifications: HP - 1.5 TANK SIZE - 8 Gallon DRIVE - 115V or 230 1 Phase CFM @ 100 PSI - 6.5 CFM @ 125 PSI - 6.2
http://www.amazon.com/Jenny-K15A-8P-Gallon-Single-Phase/dp/B002N6X51A
http://www.toolorbit.com/DeWalt/DeWalt-K15A-8P.html
parts available
http://www.mastertoolrepair.com/emglo-parts-k1a-8p-k15a-8p-k2a-8p-air-compressor-p-806.html
Re: Emglo portable air compressor
Reply #1 on:
November 14, 2012, 10:37:31 AM »
bump.. any offer...
Friendly Competitor
Friendly Competitor!
Reply #2 on:
November 14, 2012, 07:20:01 PM »
Looks clean.
I use electric primarily.
Reply #3 on:
January 03, 2013, 03:24:45 PM »
bump..
offer or scrap....
Reply #4 on:
January 04, 2013, 08:47:12 AM »
That sure would look nice in my trailer... Wonder if a 3500 watt generator would run it... hmmm
That would be better than scrapping it....
Pages: [
Classifieds
For Sale
