Author Topic: Fourth Generation  (Read 77787 times)
Re: Fourth Generation
« Reply #30 on: September 10, 2025, 07:21:40 PM »
ya NY changed something in last 5 years, you have to have a HD inspection license now.
mine is even reg as a 9800lb passenger suburban.  still need an inspection station thats heavy.
Lewis tire?
Regional international?
Jareds place?
« Reply #31 on: September 10, 2025, 10:11:20 PM »
Same as you did and going to Wilkins Friday.
Couple miles from Jared’s
Idk if it’ll force tint removal or anything else. Will have to check out the more convenient options later. Need to just get it done.
Just when I was kinda used to the inspection BS at last with a great close place. I shoulda spent that sales tax money forming a Montana corporation instead.
« Reply #32 on: September 12, 2025, 12:10:12 PM »
Stickd
Long wait. How do normies do this on the regular?
« Reply #33 on: September 12, 2025, 12:20:58 PM »
so was it that you just needed a heavy weight inspection?  Sara's shop(Duncan Milk Hauling) in Lima does heavy inspections.
« Reply #34 on: September 12, 2025, 01:08:22 PM »
Yeah, heavy and friendly.
« Reply #35 on: September 28, 2025, 10:02:06 PM »
Landed safe home. Long road day today.
No truck issues. Limited slip is TIGHT, I felt it on the wet grass maneuvering to dump tanks. I read they’re helical on the big axles.
Dash says I’m getting 10mpg give or take. Haven’t checked that math yet. Hope bigger and same weight or lighter tires might help that. I think that’s about 20% worse than the 07.
« Reply #36 on: October 04, 2025, 05:06:47 PM »
finally ran numbers. 9.8 mpg out of the truck on this trip, 9.4 worst (much of Canada, 73-75mph), 10.6 best (home to NH, steady 65).
old truck was doing 11.5-13.5 with the camper.
new truck did 11.4 running around town between when I bought it and the start of the trip. old truck would have been 14-15.
slightly disappointing & just about exactly as expected. dashboard is optimistic by 0.3 to 1.5mpg. Have not gotten over 500 miles on a tank yet.
Almost time for oil change and fuel filter.
« Reply #37 on: October 16, 2025, 05:55:24 PM »
Passenger outer dual was flat today
« Reply #38 on: October 16, 2025, 06:12:44 PM »
 :o
how rude!
« Reply #39 on: October 26, 2025, 07:54:07 PM »
Tire sounded right since I filled it. Was a bit lower than the rest at departure Thursday.
Had to hit wire trailer running lights. Plug at goose was perfect but at the tag trailer hitch the running lights give 2.3v. All others give 13.x
Need to take the plug off and see how green that lead is inside. I bridged to the 12v constant and nothing bad happened truck side. All was good.
