Author Topic: porto welder talk  (Read 35786 times)
Re: porto welder talk
« Reply #30 on: May 13, 2025, 01:33:44 PM »
i wasnt there when a failure occurred so not sure how it happened.  Probably because wire spool is taped to keep it from birdnesting while bouncing around in a rig and tape wasnt removed.  i do stock extra variable speed controllers now, and i think i got 5amp ones instead of 3A originally.  could also just delete the wire speed option, my original setup was like that running wire feed on 12v, weld circuit on 24 for years and worked fine for 1/8-3/8 duty with a skilled operator.
VA fix went awesome, toyota truck ripped out a drain plug and only solution was to weld it since threads and plug were damaged.
« Reply #31 on: May 14, 2025, 04:27:15 PM »
threw together a second kit with all new parts deleted wire speed feature.
30min assembly time.
need to clean up wire connection plan- EC5 plugs are annoying.  I had a few older iteration housings cut out already.
New case  40$
New spool gun 40$
030 spool 2lb  15$
auto darkening welding glasses 15$
HF welding gloves 10$
EC5 plugs / wire / ground clamp 20$
(4) 3s 6600 packs 120$  (cheaper than that 8500 packs i first bought, but same sizes? lol)
lipo charger 60$ (my RC car charger 150W)
320$ @ cost not bad?
« Reply #32 on: May 26, 2025, 03:03:01 PM »
got used twice on trail this weekend
Travis blew a rear ujoint that damaged the yoke cap tab so we tac welded a washer on
Joshs 1ton XJ ripped off track bar mount / hydro assist mount at axle.  recovery on this one would have been nightmare without welder.  ground clean, banged some ripped brackets back in shape, did a good amount of welding and then wheeled rest of day.
« Reply #33 on: May 26, 2025, 05:40:52 PM »
That’s a pretty neat unit
« Reply #34 on: May 26, 2025, 05:54:31 PM »
the mini grinder is sweet.  works awesome.  need to figure out how to get a die grinder bit on it some how also
« Reply #35 on: May 27, 2025, 06:41:15 AM »
Sounds like a real weekend saver!
« Reply #36 on: November 23, 2025, 10:48:48 PM »
porto welder and mini grinder got a work out 50' into rock creek today.
worked like a champ.  need to remember to wear the head sock.  got a little face sunburn after burning on a 3link axle mount that ripped off Mike S JK buggy from CT.  Wheeled rest of day.
« Reply #37 on: November 23, 2025, 10:50:48 PM »
3rd or 4th trail repair since i have charged the packs.  ill have to look what level they are at.  im thinking gen3 of this will be a single 6s 10K pack that will be easier to charge, more compact, lighter ect.
