Author Topic: porto welder talk  (Read 35765 times)
Re: porto welder talk
« Reply #15 on: August 07, 2024, 07:47:41 PM »
some electrical tape but first fully cordless weld achieved!
time for some real batteries.
the two welds shown are 1/8" to 3/16" and 5/16" to 5/16.  that was the entire power of the two jump packs to perform those two welds from 99% to 0% on one and 32% on the other  (i stopped when lack of power was noticed)
Im thinking based on the charge time at 2A usb charger, and discharge time of <30 seconds @ 94amps, they are more like 2900mah and not 29000mah packs
« Reply #16 on: August 08, 2024, 01:34:32 PM »
My welder is running two of these batteries:
https://thebatterydude.com/jb12-18-battery/
Did you measure or calculate 94 amps? That's pretty light duty for much more than 1/8"
« Reply #17 on: August 08, 2024, 07:11:50 PM »
measured.  i have a 600amp DCM clamp on meter
it burns the shit out of it and that first weld i was needing to go about 3x speed i normal weld at to not burn though
« Reply #18 on: August 21, 2024, 03:00:43 PM »
batteries and rest of small parts for variable wire speed and battery voltage monitor system
best i could find for 50$ was a 200W lipo battery charger that might be a bit cumbersome to charge that much of battery in 4 sessions, but thats really not the purpose to be needing this thing for more than one or two weekend uses
also since extra no name / no wires spool guns are 47$ on amazon i grabbed another one (looks identical to my miller gun)
« Reply #19 on: August 26, 2024, 03:41:19 PM »
waiting on charger to ship have everything else lol
« Reply #20 on: August 31, 2024, 06:50:45 PM »
new lipo smart 10A charger arrived and charging first pack.  should be able to burn some steel tomorrow.
need to make battery hold system and add wire speed control board i got also.
fun!
« Reply #21 on: August 31, 2024, 09:02:07 PM »
bah!  mixed up polarity on my load side and have all the wrong connectors and y harnesses.
boo.  no welding tonight.
« Reply #22 on: September 02, 2024, 08:13:43 PM »
new parts came in, picked at this thing a bit and did some testing.  burns nice.  I think we got something good here once its re packaged.
all said and done i have about 300$ into the entire thing with the charger, batteries, spool gun, BMS chips, variable speed board, wire, connectors, fire bag, close quarter weld glasses/sock.
« Reply #23 on: September 14, 2024, 10:40:03 AM »
Neat!
« Reply #24 on: October 10, 2024, 03:40:50 PM »
motor drive speed controller was DOA when attemted to use at FF.  2nd one i have managed to kill, but i hooked on up reverse polarity so was my fault.  ordered 3 more (7$ for 3) and will try again before sourcing something else
current unit rated for 5amps 35V.
« Reply #25 on: October 25, 2024, 08:50:51 PM »
replaced motor driver, not sure root cause
have two working units ready to go for hallowheeling!
« Reply #26 on: May 09, 2025, 05:52:06 PM »
worked good in the field welding up a toyota axle drain plug that got ripped out in VA
grabbed a HF pelican case to step up storage.  also ordered a 3" mini angle grinder that uses dewalt batteries im hoping to also fit in the case.  might make an itteration 5 of the welder housing if i can find more aluminum.
« Reply #27 on: May 11, 2025, 01:41:57 PM »
new mini grinder is sweet! and all fits with welder into meduim HF pelican case.  win.
« Reply #28 on: May 12, 2025, 06:33:09 PM »
new setup.
ordered parts to make another one.
« Reply #29 on: May 13, 2025, 10:04:57 AM »
That is a slick little setup. How did it do with the trail repair in VA? Got whatever power issues you were having last year sorted out?
