Author Topic: Cadillac CTS4  (Read 53895 times)
Re: Cadillac CTS4
« Reply #30 on: November 20, 2024, 07:44:46 PM »
Report of a breifly flashing MIL today
This thing is made of codes. Misfires all around and both exhaust cam phasers.
Still rattles like a mother on anything but hot fresh restart. GM and I really don’t get along.
It got fresh spark plugs along with the timing job and oil pump. Didn’t do anything with coils, could see about parts cannon those at it at 150k miles.
Code dump - none came back immediately. Oil has about 3400 miles on it, that’s been when cams started throwing codes the last couple oil changes. It might got one step thicker grade but it would be much nicer if it stopped draining back. Replacing the oil filter cap ( integrated check valve ) made zero difference.
Hope the evap code was a loose gas cap one time. Mom’s Mazda will have an evap code chased next week.
Car Scanner ELM OBD2
Version: 1.112.9/1.112.9/iOS
DTC report
Connection profile: Cadillac OBD-II / EOBD (2004 - present) + CANDate: 11/20/2024 7:36:23 PM
VIN: 1G6DG577390136653
OBD-IIOBD-II
DTCs: 10
P0300 [0x0300]
Random/multiple cylinder(s) - misfire detected
Status: Confirmed
P0302 [0x0302]
Cylinder 2 - misfire detected
Status: Confirmed
P0496 [0x0496]
Evaporative emission (EVAP) system - high purge flow
Status: Confirmed
P0304 [0x0304]
Cylinder 4 - misfire detected
Status: Confirmed
P0306 [0x0306]
Cylinder 6 - misfire detected
Status: Confirmed
P0014 [0x0014]
Camshaft position (CMP) actuator, exhaust/right/rear, bank 1 - timing over-advanced/system performance
Status: Confirmed
P0024 [0x0024]
Camshaft position (CMP), exhaust/right/rear, bank 2 - timing over-advanced/system performance
Status: Confirmed
P0303 [0x0303]
Cylinder 3 - misfire detected
General Electrical Failures [0x00]
Status: GM failure record
P0301 [0x0301]
Cylinder 1 - misfire detected
P0305 [0x0305]
Cylinder 5 - misfire detected
Re: Cadillac CTS4
« Reply #31 on: November 21, 2024, 04:59:53 PM »
inspect an check all engine to body to chassis to battery grounds, never hurts when multiple codes pop
Re: Cadillac CTS4
« Reply #32 on: November 22, 2024, 12:24:36 PM »
New set of codes with no repeats after 2 cycles and 15-20 miles.
I like the “General Electrical Failures”, that’s cool.
DTC report
Connection profile: Cadillac OBD-II / EOBD (2004 - present) + CANDate: 11/22/2024 12:21:55 PM
OBD-IIOBD-II
DTCs: 3
P0011 [0x0011]
Camshaft position (CMP), intake/left/front, bank 1 - timing over-advanced/system performance
Status: Pending
P1012 [0x1012]
P0341 [0x0341]
Camshaft position (CMP) sensor A, bank 1 - range/performance problem
Re: Cadillac CTS4
« Reply #33 on: December 02, 2024, 06:14:13 PM »
Well it either ate a timing chain or a phaser shit the bed
Barely avoided a sheriff ordered tow, rolled it down the hill into mark moores driveway lol
It’s been a pretty poor car week!
Re: Cadillac CTS4
« Reply #34 on: December 02, 2024, 09:39:10 PM »
No block holes. No sensors sheared. Won’t know more till I pull valve covers later this week.
Re: Cadillac CTS4
« Reply #35 on: December 03, 2024, 08:11:38 AM »
boo!  hiss!
Re: Cadillac CTS4
« Reply #36 on: December 03, 2024, 09:05:58 AM »
oh no!
Cadillac CTS4
« Reply #37 on: March 28, 2025, 08:05:38 PM »
One valve cover off, front plate on exhaust cam phaser -fell off- the cam phaser
Wtf
I knew I would regret scrapping the old phasers and chains. I really wanna see what’s supposed to hold that thing on there.
In a few minutes, I’ll see what the other side looks like… Maybe this will be as easy as a cam position sensor and a cam phaser? I’ll assume that it beat the shit out of the sensor.
Re: Cadillac CTS4
« Reply #38 on: March 28, 2025, 08:51:45 PM »
Driver head is fine
Cam is not moving with the phaser, probably have exhaust valve damage. Unsure if camshaft could be damaged as well, would depend on how the phaser is damaged. It did loosen the bolt, so will depend on whether the phaser guts are loose on the cam or if the phaser came apart
Easiest rescue would probably be a junkyard head swap. Several hundred and probably 8 - 12 hours more total?
Might get 5k out of it, more likely 3. Versus what, 500-700 in scrap?
Sounds like I should make it go away. Sarah likes it even w the Magnum and the caddy is in worse shape though it’s a bit nicer and gets way better em pee gees
¯\_(?)_/¯
Re: Cadillac CTS4
« Reply #39 on: April 10, 2025, 01:52:04 PM »
some research led to some parts and tools buying.
- not interference engine. valves should be fine
- rattle on startup is indicative of bad cam phaser (has rattled at startup forever, before and after timing set)
- phasers are supposed to have pins that lock in to static timing when there's no oil pressure. it's when those pins fail that things go badly.
- there's a tool to jam down behind the cam gears to retract chain tensioner and change phasers without pulling the timing cover.
- there's an updated right side valve cover gasket that restricts PCV and reduces oil consumption.
Both those camshafts spin - one freely and one within the range of phaser adjustment.
I bought that tool and both phasers. will retime those cams and hopefully she'll run again. Then probably send it.
Re: Cadillac CTS4
« Reply #40 on: April 10, 2025, 01:58:52 PM »
sounds like progress but annoying!
Re: Cadillac CTS4
« Reply #41 on: April 17, 2025, 12:11:04 AM »
Back together, starts and runs. Not fixed. Rattle came back shortly. Pulled the brand new vvt actuators, no ground up chunks on them like the old ones. Didn’t try unplugging and running to see if the pins lock and stay locked without actuators, idk if that’s “allowed” or a quick route to damage.
$500 with a smile to anyone here. Will drive onto a trailer.
Should have intake and valve cover pulled again for anything further than that.
At least it’s mobile again and now it’s outside and not soaking up a bay or blocking the forklift.
Re: Cadillac CTS4
« Reply #42 on: April 17, 2025, 08:07:50 AM »
wheels, cat, battery, fuel drained from it, and the Claw at metalico dropping and smashing it would probably net 500 and be more satisfying
