Author Topic: Cadillac CTS4  (Read 53894 times)
Re: Cadillac CTS4
« Reply #15 on: January 09, 2024, 05:32:49 PM »
Do you ever wonder how people live with just 1 newer car that only needs oil changes and gas?  ;D
Re: Cadillac CTS4
« Reply #16 on: January 10, 2024, 02:57:00 PM »
I do wonder how that is...
The thread for that discussion happens to be Sarah's TDI. That'll be out of daily production real soon, if not already. It's a source of friction at the moment.
Re: Cadillac CTS4
« Reply #17 on: February 05, 2024, 06:56:36 PM »
This thing is fuel stinking up the garage.
No gas drip visible anywhere underneath.
Has to be weeping somewhere and leaving a wet spot somewhere. An oil pan of gasoline smells about as much as this does. It can’t be an evap leak unless something is putting gas into the charcoal canister and it runs a purge on shutdown.
It’s always gotta be something.
Re: Cadillac CTS4
« Reply #18 on: February 08, 2024, 01:07:04 AM »
Found the drip. Rotten steel fuel lines up against side of tank. Broke in more places at clamps as I touched them.
Replaced with rubber 50psi working pressure fuel injection line from the plastic at the tank to up front where the rust stopped.
Should probably do the trans cooler lines that look equally crunchy, and send this thing. Domestics suck. Aluminized steel fuel lines? Cmon. At least the brake lines still look good. Hopefully they aren’t about to fall apart right at the nuts like they always seem to.
Smike, do you have male to nipple for these quick connects when you’re re plumbing things? I keep the females in stock but I ended up having to just cut these off and clamp over the nylon line. Extremely tight fit and pushed over far enough to double clamp so I’m comfortable with it but unhappy I had to do that. Just didn’t have the right stuff in stock or leftovers.
Re: Cadillac CTS4
« Reply #19 on: February 08, 2024, 05:06:09 PM »
i dont think i have any male ones that would be use full.  usually i just replace the whole line tank to fuel rail with two new females.
Re: Cadillac CTS4
« Reply #20 on: February 09, 2024, 10:04:12 AM »
I'd have had to drop the fuel tank to do that on this one.
Layout is a short plastic line from fuel pump ending with a female to the rotten steel line with a male, the rotten steel runs all the way forward and up the inner fender where it's swaged to a flex line that runs to the engine, and an AC-type disconnect that I couldn't take apart when I was doing the timing chains. I ended up laying the fuel rails off to the passenger side using the flex of that line. It wasn't an exact size match to AC lines and my AC disconnect tool wouldn't quite get it.
Re: Cadillac CTS4
« Reply #21 on: May 14, 2024, 06:59:39 PM »
Still REALLY need to do the trans lines and PS lines.
Sarah really likes this thing and doesn't seem interested in replacing it in spite of my urging...
Has a check engine light on for something that I haven't pulled. has a really quiet lifter tick once it's warmed up. Seems like a time bomb that I'll be stuck scrapping when it pops instead of having gotten to sell it for a couple bucks. Oh whell.
Re: Cadillac CTS4
« Reply #22 on: June 22, 2024, 08:02:37 PM »
Oil changed, 149,942
Drained oil looked good but didn’t seem like 5qt (I didn’t check before drain, and operator refuses to check oil regularly even on the known consumption issue historically with the Equinox), lots of sludge in oil filter, certainly stirred up from timing chain job. Should have done a change sooner than 4500 miles apparently,
Operator reported a loud startup recently. Sounded like chain chatter either from VVT or tensioners.
Lotsa codes behind that MIL. We’ll see what come back. None returned immediately and startup much quieter.
Readiness shows O2 issues.
Notable that GM engine management shows 53% oil life remaining. No wonder this thing was full of sludge.
Re: Cadillac CTS4
« Reply #23 on: September 22, 2024, 09:44:45 PM »
Put a new oil filter cap on this tonight in hopes that the startup rattle goes away. I don’t think it will. I don’t know if there’s another oil drain back that it could be. The cap was the next suggestion I found. It has drain back and bypass.
Changed left low beam headlight. Have to drop one side of the bumper cover and remove the headlight module (on driver side only, could remove air box and have super tight space. PDC is there on pax side). There’s steel of fender behind it. So dumb. Halogen lights shouldn’t take that much to change. Forums say it’s a $300 job at the dealer. It took me 45 minutes. Thieves.
Re: Cadillac CTS4
« Reply #24 on: September 23, 2024, 08:06:02 AM »
freaking insane...
Cadillac CTS4
« Reply #25 on: September 25, 2024, 11:34:38 PM »
Oil filter cap made no difference. Still sounds like the chains are gonna exit the block for the first half second of run time. Tensioners leak down in a couple hours.
No sludge noted on the filter though, and about 4000 since oil change. Maybe some nice, thick oil next time around.
Re: Cadillac CTS4
« Reply #26 on: September 26, 2024, 08:54:23 AM »
the tensioners are hydraulic?
Re: Cadillac CTS4
« Reply #27 on: September 26, 2024, 08:55:41 AM »
Oil pressure, yeah. Most timing chain tensioners are.
All four cams have oil-controlled phasers too, could also be involved if they empty as well.
Re: Cadillac CTS4
« Reply #28 on: September 26, 2024, 08:55:41 AM »
Re: Cadillac CTS4
« Reply #29 on: September 26, 2024, 09:10:05 AM »
Interesting
