Author Topic: new buggy build  (Read 160224 times)
Re: new buggy build
« Reply #75 on: April 04, 2024, 05:43:31 PM »
finally made some progress on cabin layout and controls today.  i think its going to work out pretty good.
Re: new buggy build
« Reply #76 on: April 23, 2024, 06:29:07 PM »
getting ready to start plumbing.
fuel cell enclosure finishd and cell mounted
hydro res mounted
battery box mounted
exhaust done and muffler hung
Re: new buggy build
« Reply #77 on: April 27, 2024, 06:06:25 PM »
PCM and TCM mounted
more chassis tube work done on the sides
gages mounted
hydro lines in
fuel system lines in
turbo hot and cold side clamped up
cooing system clamped up
waiting on the hydro return line to come in
more brake fittings and line to come in
wont be long till i can fire it, should be driving early next week i think.
Re: new buggy build
« Reply #78 on: April 30, 2024, 05:42:06 PM »
more wires
65psi oil pressure while cranking with starter motor / turbo feed bled
Re: new buggy build
« Reply #79 on: May 01, 2024, 05:14:35 PM »
fired up buggy.
imediatly noticed power steering pump not happy, dead headed.
ran output hose direct to tank to ignore that / think about it.
fought with cooling system on and off for 2 hours, cant get to bleed, bah!
fuel system good
exhaust good
wiring good
transmission still good after re assembly
50$ grab bag orbital is wrong kind.  determined its closed center with 5th port load sense.  not open center with 5th port power beyond.
Re: new buggy build
« Reply #80 on: May 02, 2024, 03:58:29 PM »
new open center 4 port orbital installed with rear steer spool valve in series.  works mint.  3.5 turns lock to lock (lots of steering angle!) and rear stear works great.
thermostat had no bleed hole and would not open to allow engine to pass coolant.  gutted t stat and all good.  if i get a new one i might put a 3/8" hole in it and keep the stat functional.
rips around good, gearing with 3.73 seems like it would be crawlable so 5.38s should be nice.
on to hit list for a shake down run.  a little bit a fabrication left and wire/plumbing clean up.
lots of work left, but glad its moving, charging, cooling, holding oil.
brakes and hubs / gears and such lol
Re: new buggy build
« Reply #81 on: May 02, 2024, 09:21:07 PM »
solid second shift on this tonight.  i left a lot of welding in hard places haha.  rear links and shocks pulled for final weld, tab paint, top locks.  need to run for hardware tomorrow.
Re: new buggy build
« Reply #82 on: May 03, 2024, 05:13:22 PM »
shocks and links locked down final.  proper test drive (FWD only, open diff, 3.73s)
limit straps in
electrical and hydro instal cleaned up
spot painting the hard places as i go.
chassis should be ready to finish paint after rest of fabrication is done like floors,roof,winch, harness mounts ect.
made some turbo noises!
Re: new buggy build
« Reply #83 on: May 04, 2024, 10:18:10 PM »
brake lines mostly run. ordered another roll of braded hose. was short.
hopefully the 250$+ i have spent total on hose and fittings is not a big fail and they hold pressure.   ordered twice and then more, big fail trying to be cheap ha.
probably on to gears / shafts tomorrow while waiting for some ods and ends parts.  i think diff covers are the only thing i need to settle on making or buying.
floor and roof tins ect, winch.
Re: new buggy build
« Reply #84 on: May 05, 2024, 08:11:56 PM »
petals remounted
rear gears in and housing painted
front axle torn down.
exhaust manifold leak someone forgot to weld 1/4" spot somewhere i was able to get at and weld while on the car!
Re: new buggy build
« Reply #85 on: May 05, 2024, 09:32:19 PM »
moving right along..   8)
Re: new buggy build
« Reply #86 on: May 06, 2024, 09:35:43 PM »
gears and shafts finished up both ends, painted.
rolled the dice on ebay drive slugs @24$ each, they look great, and fit great.  burned up some caps with some spacers.  quick fun project.
first diff cover bent up on nicks brake, test fit, half welded.  will final weld the ring while bolted to housing.  need to grab more 5/16" plate this week or just make a 3/16" one for rear.
rolling along!
Re: new buggy build
« Reply #87 on: May 07, 2024, 10:04:19 PM »
solid 10 min rip around property.  thing hawgs and shifts great, gearing is great crawls up concrete wall with ease at idle.  rear stear and front steer seem fine.
need more brakes.  i have dual 1" bore willwoods, just ordered 1.25" to get more volume.  dual piston front F350 calipers on all 4 corners taking way too much volume to do anything.  everything bled and working, just need more flow.
axles filled and done.
need some floor work, asses winch situation.  couple leaks and othe comfort items.  harnesses, roof  probably a bit more but major stuff is knocked out.
Re: new buggy build
« Reply #88 on: May 08, 2024, 11:22:57 AM »
how's the shoulder to manifold comfort and noise situation? Satisfactory?
Re: new buggy build
« Reply #89 on: May 08, 2024, 06:44:57 PM »
it was tolerable with just the initial header wrap i had.
today i added 2" of fiberglass mat and 2 aluminum sheilds over that.  the initial header wrap is like 4-5 layers thick.
