Author Topic: L110 long bed build  (Read 53802 times)
Re: L110 long bed build
« Reply #30 on: April 18, 2025, 08:42:05 PM »
got bored with this so it got pushed to storage end of barn for a couple months?!
i guess really i didn't feel like going to J&J in cold haha
grabbed everything for motor i needed, pushed over to lift bay this afternoon.
coolant sensor, map sensor, cirp belt installed
transmission shift lever, cable, dash PTO shift style knob fab'd and installed
« Reply #31 on: May 05, 2025, 03:40:36 PM »
fuel tank mounted
working towards a battery box, fuel system, wiring to fire this thing so it moves under its own power soon
« Reply #32 on: May 07, 2025, 06:31:16 PM »
fuel lines run to motor, fuel tank vent, Filler neck done
battery box / battery mounted
LS oil pressure and coolant senders mounted
fuse box and PCM mounted, turn signal switch mounted
starting on wiring to get motor fired this week.
« Reply #33 on: May 07, 2025, 06:32:50 PM »
going to be a cool truck.  8)
« Reply #34 on: May 07, 2025, 06:39:21 PM »
i guess i need to slap a tune together or find something for the bigger cam shaft in attempt to be closer
big cam
DBC
4l60
red/blue
« Reply #35 on: May 08, 2025, 05:38:11 PM »
wiring and plumbing for engine finished and first crank attempt was a fail.
looks like its not happy with crank signal agreeing with cam signal.  hopefully its just two pins swapped on the ebay harness and it will make spark then ha.
dash gages look sweet and fit right in!  super happy that the ones i use on chevy trucks (that are a pain to fit) just bolted in with no mod.  Ill probably get another set for my other international truck. GPS speedo is nice.
« Reply #36 on: May 20, 2025, 05:32:45 PM »
more time wasted on this thing and no fire.
my scan tool i cant seem to find CMP signal for this model year.  tried swaping pins and i do get a few pops now.
verified fuel pressure, injectors are free and flowing fuel.  checked PCM is spraying fuel on #1 and #2
see cranking RPM (crank signal?) but have Cam signal code.
i assume its trying to spark because i have some pops and bangs.
bah
« Reply #37 on: September 10, 2025, 07:25:30 PM »
pushed this thing back into the work bay for the first time in months.
pined out some things and did some diagnostic work.
found MAP and CMP senor plugs (same plug) swapped on engine after pinning out sensors to PCM
fresh 5.3 base tune and got it fired finally!  starts, stops, moves, steers.
i was about to give up on this ebay harness.  be good to get back working on it this fall!
« Reply #38 on: September 12, 2025, 06:55:26 PM »
intake plumbing started
full exhaust done today. 3" flowmaster sounds good.
« Reply #39 on: September 28, 2025, 08:29:20 PM »
3rd gen tahoo seats mocked up
petals shortened and adjusted.
need to get going on this and finish it up- i guess to list in spring?
Hit list
wire up dash gages
front grill tin work
front lights
mount front bumper
fab rear bumper
rear lights
finish light wiring
mount side steps
address fender, firewall, bed floor rot issues
door cards / headliner cardboard replacement
mirrors
engine cam tuning
« Reply #40 on: October 01, 2025, 01:12:19 PM »
this would be super cool on an IH
https://www.facebook.com/share/1GQL76mVHP/
