Author Topic: L110 long bed build  (Read 31679 times)
Re: L110 long bed build
« Reply #15 on: January 24, 2025, 05:27:37 PM »
box and cab pulled, started to fit to new chassis
new shocks installed front of new chassis
box fits mint on new chassis, will have to cut firewall on pass side head area but not too bad and should fit up nice.
« Reply #16 on: January 24, 2025, 08:54:17 PM »
Did the shocks fix the camber issue?
« Reply #17 on: January 24, 2025, 09:30:11 PM »
yes all good tight and right now.
« Reply #18 on: January 25, 2025, 02:35:57 PM »
body within an inch where i want it.
massaged fire wall instead of cutting for LS head clearance
sold chassis in less than a day for 250$  guy left deposit traded a mint front bumper instead of cutting this one off.  win/
« Reply #19 on: January 26, 2025, 05:44:06 PM »
desired ride hight and fitment achieved.  should be able to fab up the rest of mount needed and then pull for plumbing / paint.
« Reply #20 on: January 28, 2025, 05:54:50 PM »
all body mounts done
alum drive shaft tig'd up
tank fitted
should be ready to pull for frame paint soon after jeep work this week then start on plumbing and final assembly.
« Reply #21 on: January 28, 2025, 06:32:21 PM »
need to grab a 1350 to 1410 ujoint
Moog 499
« Reply #22 on: January 29, 2025, 09:26:19 AM »
Didn't you have issue with your big cam 5.3?
« Reply #23 on: January 29, 2025, 02:30:55 PM »
ya it sucked for rock crawling.  idle tuneing was near impossible.  even with a converter change.
it should be fine for a street car.  mechanically there was nothing wrong with the engine.  also a motor change on this truck would be 5x easier than a motor swap on the buggy.
« Reply #24 on: January 30, 2025, 06:13:07 PM »
cab and bed pulled for final welding / chassis paint.
first time spraying HF bed liner with the under coating gun,  not bad.  could have used a bit more than a gallon but made it work.  was on clearance for 33$ a gallon
« Reply #25 on: January 31, 2025, 03:05:22 PM »
body final bolted down on rubber.
steering box is going to be odd.  for some reason the older express vans they have the box input pointing way up straight unlike any other express van or truck i have done.  might have to get creative.  doesnt look easy to rotate box on frame of course.
« Reply #26 on: January 31, 2025, 03:42:02 PM »
most recent picture shows this one well. some other Express vans have a different config with some angle on that input shaft?
This definitely looks like it'll need 2 joints to get back to a normal truck column area. Agreed it doesn't look straightforward to change that box position. Sector shaft is almost dead horizontal with a pitman arm straight down?
« Reply #27 on: January 31, 2025, 04:11:39 PM »
ya i have been procrastinating dealing with the steering box.
they changed how the box was mounted with the body style change in 2002.   i need to confirm i cant just swap to a newer box but im guessing its not that simple.
it will need 3 joints and a jack shaft, or a chain drive lol
« Reply #28 on: February 01, 2025, 03:10:47 PM »
1350/1410 conversion joint installed, rear shaft in
front steering column modifyed and shafts built.  just need to mount heim support.
« Reply #29 on: February 05, 2025, 10:40:56 PM »
steering finished, works good
steering plumbed
Rad hung and mounted
trans cooler mounted
amazon harness came in today (i know ill regret a 70$ LS harness)
i guess fuel system and a battery box are next to start on some wiring.
