Author Topic: Auxiliary tank  (Read 55367 times)
Auxiliary tank
« Reply #30 on: May 25, 2012, 07:27:15 PM »
WMO Waste Motor Oil
Auxiliary tank
« Reply #31 on: May 25, 2012, 10:18:31 PM »
I got 10 gal I've been too lazy to return if anyone wants it
Re: Auxiliary tank
« Reply #32 on: May 26, 2012, 08:45:28 AM »
All needs settling and filtering anyway, nbd...
Shops apparently usually sell it for a dollar or a bit more per gallon too, could be a cheap way to get decent quantities.
If you can find a big shop that could almost keep up with your quantity that would be a score. The problem is a lot of them use the oil in the winter for heat. If you can find someone out there who has a connection with someone with veggy that is the way to go. A small lunch place with use about 15-30 gallons a week and if you get two lunch places you will be set.  If you have to pay them a dollar a gallon or something around there it is worth it. Next time you are out by me you should swing by and take a look at me and chads contraption
Re: Auxiliary tank
« Reply #33 on: May 27, 2012, 12:38:51 AM »
i will help load the shat under my deck that is about it
ha
lol
Auxiliary tank
« Reply #34 on: May 27, 2012, 01:20:52 PM »
definitely
Re: Auxiliary tank
« Reply #35 on: May 28, 2012, 09:05:09 AM »
when is the first annual lake party!
Re: Auxiliary tank
« Reply #36 on: May 28, 2012, 09:36:40 AM »
It is coming up soon! The water is still really cold tho
Re: Auxiliary tank
« Reply #37 on: May 28, 2012, 10:07:34 AM »
The water in the pool is nice, we will be in this afternoon if anyone is interested.
Auxiliary tank
« Reply #38 on: June 07, 2012, 12:48:41 AM »
Bung welded in, tank mounted, toolbox remounted. Went with tank forward. If I remove the bed the aux tank doesn't need to be screwed around with.
My filler neck isn't the size it was supposed to be so it's not plumbed in. Ford and Dodge are supposed to be 1.5", GM is supposed to be 2". I'm 2". Also found that my filler neck is toting from the outside. Has a pin hole, that'll need replacing. That, along with a working spare tire winch, are on the J&J list.
Re: Auxiliary tank
« Reply #39 on: June 07, 2012, 08:30:36 AM »
When are you heading to J and J?
Re: Auxiliary tank
« Reply #40 on: June 07, 2012, 08:42:35 AM »
i need to go to J&J too. let me know when you are going. i'm shooting for saturday.
Re: Auxiliary tank
« Reply #41 on: June 07, 2012, 08:49:15 AM »
I can do Saturday maybe?
Re: Auxiliary tank
« Reply #42 on: June 07, 2012, 09:02:06 AM »
Me 4.  Do they have Toyotas?
Its tooting?  lol
Re: Auxiliary tank
« Reply #43 on: June 07, 2012, 09:46:10 AM »
i might be down, maybe look for an ls pan or some petal assemblies
Re: Auxiliary tank
« Reply #44 on: June 07, 2012, 09:46:51 AM »
I'm out for Saturday but if someone would like to shop for me I wouldn't be opposed. I may be able to do the 16th?
