Author Topic: wonder 6.0 2006 LJ  (Read 48930 times)
wonder 6.0 2006 LJ
« on: October 12, 2022, 09:44:59 PM »
picked this guy up tonight and drug on to a trailer
was no start.  smoking wires when i hooked battery up.
cut all non oem wires out (impressive amount)
driver door un stuck
trash emptied
fired right up, 123k on it!
need to make a J&J list
some flat tin work on rockers doesnt look bad
front glass broke sadly
needs deep cleaning inside and out
tires
top is shot
front drive shaft
otherwise, good unit.
Re: wonder 6.0 2006 LJ
« Reply #1 on: October 12, 2022, 09:46:20 PM »
also note, this hasent moved since i was paid to put a transfer case in it a month or two back.....  sale price wasnt much more than that bill....
« Reply #2 on: October 13, 2022, 11:52:21 PM »
front tube fenders Hooke
rear tube fenders smitty built
3/16 moto built rockers
3/16 moto built rear corner wrap arounds
thats about 1500$ in bolt ons that should pretty much reskin the jeep
need to run numbers and evaluated ROI
« Reply #3 on: October 14, 2022, 07:58:16 PM »
good 3 hours of pillage today.  only 3 tjs and 3yjs in the yard.  no XJs, sad face.
didn't have the ambition to tackle the burb and found the mid seat isnt what i want.  i should grab some door cards and belts though.  that burb interior is mint.   picked up a set of complete TJ hard doors for Matt to sell also.  100$ bill got me todays plunder.  winning.  most all installed on the LJ tonight.
my list is ambitious:
TJ:
Gas cap
Front drive shaft
Rear lift Shocks
Front tubular lca
Front bumper
Windsheild/glass
Driver hard door mirror
Driver hard door inside handles
Both outside hard door handles
Rear view mirror
Center consol plastic
Shifter knob Trans
Center dash trim piece plastics
Radio
Hood latches
Driver seat belt assembly
Spare tire mount
Front marker lights
Front marker light harnesses
Tailgate latch cover
Coolant tank cap
Headlight bucket pass side plastics
tailgate
rear bumper ends
rear bumper
carpets grey
broken hard TJ top to make LJ half cab?
90s burb
middle seat
belts
door cards
carpet
« Reply #4 on: October 14, 2022, 09:21:06 PM »
rear corners and sliders on the way to start thanks to Joe's full hydro install labor
hopefully that pair of green TJ doors from the yard to Matt will pay for some front tube fenders and we will be rolling!
« Reply #5 on: October 15, 2022, 07:20:48 PM »
preped and rusty primered all rust areas.  95%will be removed or covered with armor
pulled all carpet and roll bar padding.
cut roll bar
front broken glass removed tonight
i think its going to look great like a truck :)
« Reply #6 on: October 15, 2022, 09:43:12 PM »
probably should have just called a glass guy but i kinda want to learn this process
remove a glass pane from yard, clean it.  that saves me 160$ and was basically free.
remove broken glass from jeep, clean frame.
not sure if inner gasket is re usable, but i cut it in a few places meh.
need new inner and new outer gasket, urethane sealant?, possibly primer?
each gaskets and a tube of sealant is 25$ each,
i guess it be 300$ to call a glass guy?  i put in a quote request for ray sands to install used pane with new seals, see what they come back at.  if its like 150$ or less i probably go that route
« Reply #7 on: October 15, 2022, 10:01:08 PM »
Have them do it for you, watch and take notes
« Reply #8 on: October 15, 2022, 10:32:00 PM »
i could just got to home depot and get a 9$ tube of roof and window sealant, use the old inner and outer seals, and get what i get on the cheap lol
« Reply #9 on: October 15, 2022, 10:33:56 PM »
rear shocks, front brakes and some axle seals on the way from Rockauto.  they had the missing hood catch piece for 10$ too!
carchameleon
« Reply #10 on: October 16, 2022, 08:57:19 AM »
I'm a little jealous of this...
always liked this lj and lj's in general
« Reply #11 on: October 16, 2022, 09:40:10 PM »
moved tonight, new radio installed doesn't power up, sad face
harness had a gazillion crimp splices so not supersizing.
« Reply #12 on: October 17, 2022, 03:53:10 PM »
day 3 on this
front pads and rotors changed
swapped out a stuck front passenger caliper
replaced a missing lift kit lower control arm
added wheel spacers, mustang GT wheels, fresh 35" Maxxis SCR tires
« Reply #13 on: October 17, 2022, 07:35:04 PM »
lowes trip yielded a 10oz tube of goo that says its adhesive for many things including glass and metal, so for 9$ i gave it a wherl and stuck the old glass seals back in and glued it in.
tips on internet:  cut caulk tip in a "V" and cut a 1/4"x1/4"x1" chunk of rad hose rubber and place at bottom of channel to help glass center and not sag to bottom while drying.   i guess the idea is to have the pane relaxed, centered, and not touching anything hard to keep it in one piece.
bam, 9$ fix
« Reply #14 on: October 17, 2022, 09:03:18 PM »
Nice work
