Author Topic: next hot rod  (Read 5748 times)
next hot rod
« on: November 24, 2020, 04:03:20 PM »
picked up another Van sunday.  2006 3500 6.0   with a 30k jasper trans
no start, but brakes and rolled, winched on trailer.  came with 3 extra mounted E rated tires/ wheels.
drug in shop today.  PO claimed bad starter.  found locked AC pump and locked alternator.  with no belts, fired right up first crank, shifts and moves fine.   trans line spring a leak- so that go bipassed.
started stripping today after some shop clean up.
« Last Edit: November 24, 2020, 05:27:20 PM by M4wdFab »
Re: next hot rod
« Reply #1 on: November 24, 2020, 04:35:36 PM »
sweet score!
Re: next hot rod
« Reply #2 on: November 24, 2020, 04:47:19 PM »
I love it!  Love seeing your build threads.
Are you using the body from Gif for this one?
Re: next hot rod
« Reply #3 on: November 24, 2020, 05:26:56 PM »
no thats the 52 project build thread.  that's already running and driving on a 2005 3/4 ton 4.8/4l80 chassis.   waiting on some door bits and window track from LMC truck- really only 1 or 2 nights on that one till its done.  this will be the next, and im actually working on another AWD van to pick up tomorrow hopefully.
Re: next hot rod
« Reply #4 on: November 24, 2020, 05:28:36 PM »
some bonus tools found in this one, and also has a nice power inverter under the driver seat, and another good four 100$ cats on it.
a few things listed for part out tonight to grab some cash back possibly.
Re: next hot rod
« Reply #5 on: November 24, 2020, 05:47:55 PM »
AWD?!
Re: next hot rod
« Reply #6 on: November 24, 2020, 05:56:38 PM »
yes sir
Re: next hot rod
« Reply #7 on: November 28, 2020, 04:34:42 PM »
solid day on this, van shell pulled, chassis prep started.
replaced seized alternator and got acc back together
Re: next hot rod
« Reply #8 on: December 01, 2020, 05:52:32 PM »
converter guy quoted the 4 converters at 140 a piece if i drop them off.  that pays for the van
sold 2 mounted erated tires (20% tread) for 80$ also today.
probably load the shell tomorrow morning and do the scraps
Re: next hot rod
« Reply #9 on: December 02, 2020, 03:12:14 PM »
shredder feed up to 200/GT   so 2300lb van shell came to 205$
4 converters dropped off at 145/piece so 580$
