Author Topic: new house for mikemike  (Read 226754 times)
Re: new house for mikemike
« Reply #375 on: September 26, 2020, 07:53:51 PM »
« Reply #376 on: September 26, 2020, 08:01:24 PM »
free scrap i hope?
« Reply #377 on: September 26, 2020, 08:21:05 PM »
Bit more than that. Like 2-2.5x scrap price.
« Reply #378 on: September 27, 2020, 06:30:46 AM »
I was wondering where you were going heading South towards Honeoye yesterday.. you passed our convoy when we were headed to the barn.
« Reply #379 on: September 30, 2020, 01:32:11 PM »
both motors on the mill run well, but pop the breakers after running for a while. And pop quickly subsequently, so it's like they need cooldown time.
I wonder if I somehow have my phases mis-identified and I'm backfeeding something?
phase-o-matic is labeled A-B-C and I've treated that as 1-2-3.
Guess I need to do some wiring research?
yall have any tips? maybe on identifying a mis-wiring? I do absolutely definitely have everything wired for 208/240 low voltage not 440 high voltage. one of these motors WAS test run after lead change so should assuredly be good. The other was short a support bearing to be test run after wiring.
« Reply #380 on: September 30, 2020, 01:44:17 PM »
Motor is to run on 208 or 240v?
My electrician friend told me a bit while ago that 208v motor *can* run on 240v but its not recommended. Motor will run hot and shorten lifespan
« Reply #381 on: September 30, 2020, 01:56:04 PM »
phase dont really matter, switch any two and it changes the motor direction.
208/220/230/240 meh same in house voltage, you probably have 218-225v at your termination anyway.
get a clamp meter and see whats pulling where.  maybe your breaker is crap or something is undersized.
« Reply #382 on: September 30, 2020, 01:56:08 PM »
Just re-verified wiring is consistent
I’m running no transformers, just rotary phase converter. Haven’t measured wall voltage.
My idler motor does not have a data plate.
Both mill motors marked as 220/440.
Lathe motor older than dirt and has no data plate.
Disconnects that are popping are identical for both mill motors and are this. I think this was running on 220 at the brewery, but I don’t remember for certain
« Reply #383 on: September 30, 2020, 02:12:35 PM »
No amps on b/2 which is the phase converter’s created leg.
Voltages are 200/210/235 between the legs.
The light on the phase converter acts as it did before I blew the capacitor and resistor. The motors work and sound right which they did not before I replaced the blown parts.
I guess I’ll check my wiring at the reverser switch and at the motors to see if I have an open on green and they’re running on 2 legs
« Reply #384 on: September 30, 2020, 05:23:54 PM »
i meant amperage readings to learn something.  a clamp on amp meter.  AC ones are common, mine goes to 600amps DC too :)
« Reply #385 on: October 01, 2020, 01:35:58 PM »
Fence removal is extreme property improvement.
« Reply #386 on: October 01, 2020, 01:40:56 PM »
Nice shot of Titan taking a dump...  :P
« Reply #387 on: October 01, 2020, 07:21:30 PM »
Hahaha
Nah: tail down, he was in process of sitting or standing up.
« Reply #388 on: October 01, 2020, 07:38:38 PM »
Finished drilling a hole on the mill. Ran for 2ish minutes before shutdown.
Zero power going from idler motor on the dead leg. Confirmed wiring from switch to disconnect.
Swapped 2 wires to reverse crossfeed motor, now it works as it should - but also still draws nothing on the dead leg and also pops its disconnect breaker.
I don’t understand how I have no draw on one leg with the idler motor going. Even if I did something wrong in fixing the phase converter, the idler should be doing its thing. It has no current on the dead leg at all.
I haven’t checked that leg with my lathe running.
I also haven’t tried pulling out the idler motor and going to just static converter.
Hrmph.
« Reply #389 on: October 02, 2020, 09:44:59 AM »
reread the phase-o-matic documentation and saw it indicated to put a SPST in the B wire if using an idler motor. I just did that, and symptoms did not change.
I didn't have a good angle to get the clamp around the B wire, but I expect it still has no draw, and that the differential draw is what's popping the 3ph breaker.
