Author Topic: new house for mikemike  (Read 224850 times)
Re: new house for mikemike
« Reply #150 on: June 11, 2020, 10:17:14 PM »
Bit better, yes. Still a fair bit o cash.
« Reply #151 on: June 14, 2020, 05:03:32 PM »
Very tight, but it does fit with a pallet on.
« Reply #152 on: June 14, 2020, 10:57:37 PM »
I think the upstairs storage and shelving will be over half full with my crap. Nice to get to sort things out, hopefully i have the discipline to not sit on things that really will never get used. Throw out pile is growing as i unpack.
Need to get shelves set up for specialty tools in cases, and refill the bolt bin. Workbench set up, not sure it’ll stay where it is but I can stop using the lift for a bench now and put more tools away. Chipping away!
Definitely don’t feel like day job tomorrow.
Two more weeks till furlough.
I should set a goal of tearing the Ram apart so I can have that back on the road and try to find a local friendly shop for inspection stickers to get the collection legal-able.
« Reply #153 on: June 14, 2020, 11:02:46 PM »
I got the mill head on. Wasn’t a fight at all, solo.
Idk if this is final location or not. Didn’t test if the lift could pick the assembled machine. Expect it can.
I’m about 22’ from the one existing 240 outlet on this side of the shop (which is in a meh location. Bottom of the stairs). Also about 28’ from the electrical panel.
« Reply #154 on: June 15, 2020, 07:57:43 AM »
I dont know much about local shops but I know one Hemlock way that does not bother if you need one.
Sent from my SM-N970U using Tapatalk
« Reply #155 on: June 15, 2020, 06:34:55 PM »
When your maintenance rig is full of crap and it’s finally garbage day for the first time since moving
« Reply #156 on: June 19, 2020, 12:13:56 PM »
lightbulbs just got here. 72" box is big n heavy
going to borrow a scaffold from Erik. Gonna clean out birbs while that's here too. I can't wait.
Fuckers are loud and annoying from the office.
« Reply #157 on: June 21, 2020, 09:43:21 PM »
Popped in 6 of these bulbs in easy access fixtures on the old side. I’m quite pleased, especially up front where the old bulbs were real tired. Didn’t see if my amp clamp might tell me anything about the true upgrade. That could be interesting. Bet I’ll continue to forget to do that.
« Reply #158 on: June 23, 2020, 04:17:18 PM »
Lots of “drool” under house gutters. But not garage. Cleaned out yesterday, and should not have been overflowing, but I didn’t verify.
I wonder if drip edge is too short?
Disappointing from a “don’t rain in my windows” perspective.
« Reply #159 on: June 23, 2020, 04:54:50 PM »
Not pitched correctly?
« Reply #160 on: June 23, 2020, 05:30:16 PM »
Garage gutter has a pitch issue. Looks like the two-car-wide-door’s header has sagged an inch or two and caused that. The others drain well enough pitch wise. I don’t think they are peeled away from the fascia, causing a gap. But I’ll look closer at that.
« Reply #161 on: June 23, 2020, 05:37:27 PM »
Also check for clogged down spouts.
« Reply #162 on: June 23, 2020, 06:41:21 PM »
cleaned them, and unplugged a couple downspouts, during yesterday's second rain. will double check...
« Reply #163 on: June 24, 2020, 10:23:44 AM »
I have 3 workbench tops if you want them.  they are just 2x4 frame and osb top- but will end up in burn pile.  they were the tables i built for under my old apartment.  remind me tonight if you want them- they are in the lower barn.
« Reply #164 on: June 24, 2020, 11:21:29 AM »
I would take those if Mike doesn't want.  I'm fittin to build a new workbench in my basement this weekend.  Slowly turning my basement into a bike shop lol.
