Author Topic: Harry's Buggy  (Read 58746 times)
Re: Harry's Buggy
« Reply #135 on: August 25, 2021, 01:58:35 PM »
It runs! fired right up without any drama.
Next:
Wrap up engine and fan wiring
Install gauges/switches into dash
Build driveshafts
Hydraulic plumbing - DJ knows a shop that will let us pull it in and make all the hoses ourselves.
Then it should be ready for a test drive around the yard.
Aside from any major issues that could arise... left will be:
F/R winch install and wiring
Shock charge/oil fill
Install and wire headlights and winch lights
Re: Harry's Buggy
« Reply #136 on: August 25, 2021, 03:21:28 PM »
Cool man!  Thats a big milestone.
Re: Harry's Buggy
« Reply #137 on: August 25, 2021, 04:29:44 PM »
Awesome!!
Re: Harry's Buggy
« Reply #138 on: August 30, 2021, 09:28:45 PM »
Test drive tomorrow
It’s tiny
Re: Harry's Buggy
« Reply #139 on: August 31, 2021, 08:56:43 AM »
doin work!
Re: Harry's Buggy
« Reply #140 on: August 31, 2021, 11:00:55 PM »
Runs
Drives
Shifts
Steers
Cools
Huge win on all those fronts. Unknowns I’m not longer concerned about.
Brakes need bled
Shocks need more pressure
Steering stops need trimming
Punch list of small, easily achievable items left. Off all next week and Fall Crawl the weekend after. Aiming there for a shakedown.
Re: Harry's Buggy
« Reply #141 on: September 01, 2021, 09:51:06 AM »
Awesome!  Love seeing a project nearing completion.
Those the tires you're running on it?
Re: Harry's Buggy
« Reply #142 on: November 14, 2021, 03:45:48 PM »
This thread deserves a lot of updates that will come soon enough… but here’s my temporary fix for the disconnect issue.
Re: Harry's Buggy
« Reply #143 on: November 15, 2021, 07:49:49 AM »
I don’t understand the cut off tack weld part of that.
Glad to see the splines are whole though and the clamp on collar makes sense.
Re: Harry's Buggy
« Reply #144 on: November 15, 2021, 08:19:41 AM »
Tack welds prevent the collar from sliding in the other direction. It should never slide that way and that's where it kept going at Rausch.
There is a plastic bushing where the male nub on one shaft engages the female pilot on the other and it was completely MIA. That leaves the collar as the only piece keeping the two shafts in alignment which it's really not suited to do, and I'm sure left no chance of a couple hose clamps keeping it where it needed to be for my trail fix. That was also replaced and I plan to have a brass replacement to go in the next time it comes apart.
Re: Harry's Buggy
« Reply #145 on: November 15, 2021, 11:26:57 AM »
makes total sense! and some brass or oilite is exactly what that needs.
Re: Harry's Buggy
« Reply #146 on: March 21, 2022, 12:23:29 PM »
Last disconnect lockout attempt lasted about 1/2 day of wheeling. Back to popping under heady load just like at Rausch. Left in trailer until yesterday.
Pulled apart everything, fresh nylon bushing is destroyed, male splines on disconnect shaft are wasted.
Noticed drivetrain moving more than I'd expect shifting from R to D. Checked 3rd drivetrain mount and found this:
Chased threads with M10 tap but when reinstalling new bolts, the threads did not survive umph with with 3/8 ratchet. I was able to run a 7/16-14 tap up through the holes and installed new bolts that did pass the umph test.
After a little thought, I ordered a 7/16-14 bottoming tap and some grade 8 threaded rod. Plan to bury studs in there with red loctite. Hopefully better clamping force can be achieved and if they do loosen up, my hope is that the studs hold tight while nuts come loose preserving the threads in the bosses.
I am thinking excessive drivetrain movement was a major contributing factor in how quickly the last two lockout/repair iterations lasted. I am currently in the process of designing a solid replacement shaft. I have every intention of revisiting the disconnect but haven't come up with anything I feel more confident in yet - considering taking apart a transfercase to see if I can borrow some components to make something more robust. Solid shaft will get me back in the woods and will serve as a good backup to throw in the trailer once the new disconnect is designed.
Other things to do:
Exhaust flex connection is blown out
Ram guards - bent a rod at F&F in October
Hood and door skins
I see I really need to get this thread caught up to it's current status... I really let it go once I got it running. Here is mostly up to date pic from the starting line at Humble Pie.
Re: Harry's Buggy
« Reply #147 on: March 21, 2022, 06:51:36 PM »
can you source a better coller that has like 2" of engagement on each side when ingaged?
would be a cool project for my G&E shaper to make one.   then get it heat treated or something fancy.
random thought, find a drive shaft slip yoke thats same spline and cut the yoke off to make a 4 or 5" collar?
In all honesty id be bored of this failure at this point and replace it with a solid shaft and delete this function.
Re: Harry's Buggy
« Reply #148 on: March 21, 2022, 07:31:48 PM »
driveshaft slip seems like good parts to use if there's 15" of shaft to play with. I don't think there's that much room here though is there?
agreed on value for effort until and unless this becomes a points-chasing cone dodger where backups matter
Re: Harry's Buggy
« Reply #149 on: March 21, 2022, 07:36:49 PM »
15"?  huh?
no like find a slip you to cut the yoke part off and make a better collar
