Author Topic: The G83C yale  (Read 9841 times)
The G83C yale
« on: March 22, 2019, 09:14:12 PM »
unknown year
7400lb machine
4K lift
looks like it has the 225 slant chrysler gas motor.
after a few cranks start munched it self but it appears to be in mostly working condition.
probably end up converting to LPG since i have the parts.
starter motor cross info
Prestolite MDU6019 46-12846-2427MDT6012MDT6012C MDT6012BT
Hyster 3003786
Yale 2200521-055099304-00 599904-00
Wilson 91-06-1906 91-06-1865
Chrysler 1941118
Onan 191-1209
Re: The G83C yale
« Reply #1 on: March 22, 2019, 10:26:34 PM »
Good numbers.
Can’t check Midwest inventory from home.. nada in Buf or Syr.
Re: The G83C yale
« Reply #2 on: March 23, 2019, 04:33:50 PM »
im gona not be impatient and not order one from amazon to be here Wednesday.   If i can walk into the electrical /starter place at on Emerson st and get a 5-20$ part to fix my starter since its in great shape other than broke gear, ill try that.  if not i bet they stock one.  wont make a second trip.
thought i was going to be slick and use some parts from the 48 chevy  chassis, but it just wasnt going to work right and risk more flywheel damage.
gathered my propane bits, i have enough to run it short term on a grill tank.  but need some fittings to go back to an actual liquid fork tank (which i sold my last one to wolfi not too long ago ha)
Re: The G83C yale
« Reply #3 on: March 29, 2019, 07:55:53 AM »
ended up just ordering a new starter.
added a gravity tank (1gal surge tank from Ford cooling system) and filter.
shop lot donuts and picking things up complete!
Re: The G83C yale
« Reply #4 on: March 29, 2019, 09:10:22 AM »
!!!!!!Awesome!!!!!!
Re: The G83C yale
« Reply #5 on: March 29, 2019, 09:47:20 AM »
still dont quite understand clutch.  95% of travel doesnt do anything, and then its almost like its a hydralic valve not a mechanical clutch.  I havent pulled the floor tin to inspect whats going in in the transmission area.
plan to pull and eval fluids.  so far coolant looked green and ok, engine oil was present.  trans looks like milky atf, cant find where to check either hydro systems.  i think steering is separate from lift / tilt.
needs a battery hold down and one of the side pannels is missing.
needs a light bar and probably a bigger fuel tank.
Re: The G83C yale
« Reply #6 on: March 29, 2019, 11:13:53 AM »
i remember the clutch being wonky...
we used it to pack up the store and I hit the back of the trailer a few times..
much easier with a skid of rotors
Re: The G83C yale
« Reply #7 on: March 29, 2019, 06:29:50 PM »
is it a clutch like a jeep? or somethign weird and hydro?
first job tomorrow, i will enjoy not loading a 14 bolt by hand.  haha
Re: The G83C yale
« Reply #8 on: April 13, 2019, 11:38:51 PM »
apparently the locals on FB thing this thing is too loud and has a roaring engine at all hours of the night.
used for 5 minutes to lift an oil tote from brets truck.
morons.  just morons.
Re: The G83C yale
« Reply #9 on: April 14, 2019, 04:21:11 PM »
 I saw it on the highlights and just laughed
Re: The G83C yale
« Reply #10 on: April 14, 2019, 07:15:42 PM »
I left that group. Couldn’t stand the raw unfiltered humanity. Final straw was some busybody minding neighbor’s visitors coming and going all night. I suggested minding her own business.
Re: The G83C yale
« Reply #11 on: April 15, 2019, 12:05:40 PM »
lol, its a good read, my fav is when some lady says to tell the landlord on you
Re: The G83C yale
« Reply #12 on: April 15, 2019, 03:08:06 PM »
what a joke.  screw those people.  im done caring.
Re: The G83C yale
« Reply #13 on: April 28, 2019, 10:56:10 PM »
did work today.  90% of shop moved.
had to have been 30k gross felt HEAVY
Re: The G83C yale
« Reply #14 on: April 29, 2019, 03:24:54 PM »
love it.....
