Author Topic: 8.8 pinion junk  (Read 1044 times)
8.8 pinion junk
« on: June 24, 2018, 08:03:34 PM »
I just laid out all my crap for the 8.8 swap in the bro lite, and I’m short pinion bearings, pinion seal, pinion nut, and pinion races. Also could use a set of set up bearings. Anybody got me covered?
Re: 8.8 pinion junk
« Reply #1 on: June 24, 2018, 10:00:24 PM »
you only need an inner pinnion setup bearing and i think its the same as D44 as i have done many 8.8s with what i have.
i might have a full or partial 8.8 kit also.  i can look tomorrow.
Re: 8.8 pinion junk
« Reply #2 on: June 25, 2018, 06:48:28 AM »
I have a full Timken 8.8 kit in the garage from the YJ.
Spider gears and an Aussie I think
Re: 8.8 pinion junk
« Reply #3 on: June 25, 2018, 09:01:43 AM »
too bad nobody seems to be racing the fuckers.
Re: 8.8 pinion junk
« Reply #4 on: June 25, 2018, 10:12:48 AM »
I was thinking about that but I'm tired of tripping over the 8.8, it's in my way.
Re: 8.8 pinion junk
« Reply #5 on: June 25, 2018, 10:59:24 AM »
trucks arent heavy enough to be useful with more rear brakes, if the 7.5 was going to break it would have broken long ago after 4 dozen 30' jumps.  I dont think i have any interested in adding the weight of 8.8 and my 4.10 gears are fine
Re: 8.8 pinion junk
« Reply #6 on: June 25, 2018, 12:37:48 PM »
I need more rear weight (I'll try and remember to check weight gain, I'm curious), I could use more gears since I think I'm 3.55 now. Hoping the 1" longer pinion is fine. I think there's about 2" of slip in left from ride height as-is.
Re: 8.8 pinion junk
« Reply #7 on: June 25, 2018, 12:56:31 PM »
i think its not fine, Erik broke something on his truck because of it.  your new perches should be able to move back the axle though it looks like 1-1.5" thats needed.
Re: 8.8 pinion junk
« Reply #8 on: June 25, 2018, 01:47:50 PM »
yes, 100%. I looked and thought of that yesterday then forgot when I was typing.
Re: 8.8 pinion junk
« Reply #9 on: June 25, 2018, 01:52:10 PM »
fix clutch issue before changing out a perfectly good rear axle? lol
Re: 8.8 pinion junk
« Reply #10 on: June 25, 2018, 02:32:51 PM »
done
