Author Topic: Diagnosing Twist  (Read 17310 times)
FallibleXJ
Diagnosing Twist
« on: February 14, 2018, 12:18:37 PM »
This is likely something simple I'm just overthinking. My CJ sits 2-3" lower on the front passenger side than any other side. How do I determine if this is being caused by a warn leaf or a twisted frame?
Re: Diagnosing Twist
« Reply #1 on: February 14, 2018, 12:54:18 PM »
A flat plane can’t be low on one corner only. Those frames do twist though. Jack that corner up and see what it does. It’ll straighten or it won’t.
« Reply #2 on: February 14, 2018, 01:51:22 PM »
Google "CJ lean" and get ready for hours of reading..
« Reply #3 on: February 14, 2018, 01:52:47 PM »
if you don't want to read...
and get frustrated with all the backyard engineers and out their ideas that boil down to nothing...
add a longer shackle to the side that leans... done
« Reply #4 on: February 14, 2018, 03:44:33 PM »
measure spring plates to frame
measure shock shaft showings
observe tire to wheel well gaps.
3" is A LOT on a CJ, problem should be obvious or at least measurable.
spring or body mount issues could be present.  those frames are flexible enough to contour to any issues bolted to them.  check tire pressure
Historically CJs always have a driver side lean because the rear driver spring is whooped.  odd your passenger side is lower.
