Author Topic: Wanted: SM465 of any kind  (Read 2502 times)
« on: November 14, 2017, 11:24:41 AM »
Tom is trying to get at least a functioning transmission for his '64 CJ5 with the Chevy V-8.
It used to have T14 3 speed. We're missing parts and cannot locate a front bearing retainer anywhere so he's considering to abandon rebuilding the T14. Do anyone have a SM465 for sale? Either 2wd or 4wd will work just fine.
Re: Wanted: SM465 of any kind
« Reply #1 on: November 14, 2017, 12:13:46 PM »
Don't have a sm465 but do have a sm465 to dana 300 adapter.
« Reply #2 on: November 14, 2017, 12:20:55 PM »
I think I have a "modern" SM465 in the shop, GM bell housing and hydro throwout bearing
« Reply #3 on: November 14, 2017, 04:33:35 PM »
is that the one i gave you mark?
« Reply #4 on: November 14, 2017, 04:36:30 PM »
Yup. Didn’t that come out of a dump truck or something?
« Reply #5 on: November 14, 2017, 04:38:10 PM »
it was out of an 84 K30
« Reply #6 on: November 14, 2017, 04:39:48 PM »
trying to fit anything chevy into that little short CJ5 isnt going to work
the 3 speed trans i gave you didnt bolt up with the adaptor you had?
« Reply #7 on: November 14, 2017, 04:53:46 PM »
Offroad Design makes a 32spl tail shaft and adapter to make a super short and stout combo.
That was going to be my solution if the auto didn’t work out.
« Reply #8 on: November 14, 2017, 04:56:08 PM »
Enlighten me on why it won't fit?
T14      8-11/16" long
SM465 12" long
The SM465 bolt directly to the bellhousing we have, so no adapter needed, not 3" longer as if we reuse the adapter.
Nope.
« Reply #9 on: November 14, 2017, 05:00:05 PM »
If we do use a SM465, chances are we will use this. Only 1" thick.
https://www.novak-adapt.com/catalog/adapters/transmission-to-transfer-case/sm465-to/kit-462/
« Reply #10 on: November 14, 2017, 05:02:07 PM »
Tom have the overdrive unit on back of the D18, making it a 5 speed with a 4 speed main transmission  8)
« Last Edit: November 14, 2017, 05:05:55 PM by TrailTamer »
« Reply #11 on: November 14, 2017, 05:06:14 PM »
You really have 6 forward, 2 reverse...
Overdrives don’t increase speed.. they just reduce operating rpm..
So you can run at 50 mph 500 rpm less
« Reply #12 on: November 14, 2017, 05:14:20 PM »
i guess when i said it wasn't going to work, i delete confounded expensive solutions to force fit big things into small holes for my mind.
« Reply #13 on: November 14, 2017, 05:16:40 PM »
you will also find that 4" in an early CJ5 is enough to make you have to start to push the engine forward like i told tom i did in mine.  your early CJ is even shorter i believe than my 75, 81, or 83 would be.
« Reply #14 on: November 14, 2017, 10:42:53 PM »
i had a 60's CJ5   Buick 225 / T98 / d300 texas bolt.   This was the the shortest & strongest combo at the time.   I was on 36" TSL SX tires.  2.5" lift SOA.
My rear driveshaft was crazy short and high angle.  you can see it in the bottom pic
