Author Topic: 2001 Tacoma  (Read 25852 times)
2001 Tacoma
« on: April 05, 2012, 06:10:29 PM »
Truck has existing 2.5" lift kit and is tearing front CV boots monthly
I have ordered All Pro Extended CV boots and should be good for install next week or week after race.
Re: 2001 Tacoma
« Reply #1 on: April 19, 2012, 10:06:00 AM »
this is being dropped off tonight.  should be a 2 night job and a good challenge.
Enginerd
  • Jr. Member
Re: 2001 Tacoma
« Reply #2 on: April 19, 2012, 12:49:32 PM »
I assume you've separated CV shafts before?
Re: 2001 Tacoma
« Reply #3 on: April 19, 2012, 04:21:13 PM »
nope lol
read about it but i guess i should read more  haha
Enginerd
  • Jr. Member
Re: 2001 Tacoma
« Reply #5 on: April 19, 2012, 09:06:23 PM »
It's pretty simple to get the hub/knuckle torn down.  There is a thin rubber seal between the wheel bearing/hub assembly and the knuckle that may not survive the reinstall.  The axle nut should be a 35mm... at least that's what it is on mine.  Once you get the axle on the bench, the easiest way to separate the inner and outer shafts is here... http://www.youtube.com/watch?v=YEaWyxF1S7o
Re: 2001 Tacoma
« Reply #6 on: April 19, 2012, 10:28:46 PM »
this was fairly straight forward, 4 bolts, a nut and the shaft is out.    one of the CV things spat out the needles when i took it apart so that took about 30min additional time that i was smarter on the 2nd side.  installed new boots, filled with new grease.  clamp suppled crashed to lower balljoint so HD nylon ties were used everywhere.
5 hours to do both sides, boot upgrades, grab something to eat, and run to wallmart for some gear oil, change both diffs.
followed the FSM to remove the tie rod from the first side, didnt need to do it and didnt on the second side.
not bad for M4
Re: 2001 Tacoma
« Reply #7 on: April 19, 2012, 10:37:55 PM »
no need to dissamble the birf to change the boots.....  just pull the inner snap ring and swap boots
2001 Tacoma
« Reply #8 on: April 19, 2012, 10:46:38 PM »
Interesting.
I swung by, probably when you were at the Mart of Wals.
Re: 2001 Tacoma
« Reply #9 on: April 19, 2012, 10:55:43 PM »
much better than i expected since the FSM said i need 4 specialized tools...
Re: 2001 Tacoma
« Reply #10 on: April 20, 2012, 12:39:34 PM »
had to trim some bolts at pick up that i missed.  questionable clearance but it probably needed to be done.
Dom says there is a grind noise also on his way home at slow speed.  i didnt hear anything when i did a test drive hmmm
need to call alpro and bitch, the 5$ clamps they said i needed crashed with the ball joints and no chance they would even almost fit.
Re: 2001 Tacoma
« Reply #11 on: April 20, 2012, 01:21:11 PM »
this hawg should not have any birfs lol
Re: 2001 Tacoma
« Reply #12 on: April 20, 2012, 10:36:21 PM »
Finially a break!  Passenger brake backing plate was bent and rubbing on rotor.  So happy a two min fix instead of another 4 hour R & R to try and chase unknown
Re: 2001 Tacoma
« Reply #13 on: May 01, 2012, 01:33:35 PM »
got a call its leaking grease.
just called Allpro and told them their clamps they provided got thrown in the garbage and i had to put nylon ties on so customer could leave.
they were unaware that what they sent does not look like what is on the website, a lower profile band clamp type.
Guy said to try to find a correct clamp solution local and send him a copy of the costs they would riemburse for cost.  kind of a hassel but i guess better than expected.
https://www.allprooffroad.com/9504frontsuspension/282
