Author Topic: The Profender 4-seater  (Read 132397 times)
« Reply #150 on: March 03, 2012, 06:37:51 PM »
Just need to move the rod on the pedal arm. No extra room needed. Move it further away from the pivot point gives it more stroke.
I dident goto college, but I think thats how it works. :)
Re: The Profender 4-seater
« Reply #151 on: March 03, 2012, 06:39:55 PM »
O0
« Reply #152 on: March 03, 2012, 06:51:06 PM »
Looks about 12 inches taller that it should be.
« Reply #153 on: March 03, 2012, 06:58:19 PM »
It's 6 inches higher than when riding on the bumps.
« Reply #154 on: March 03, 2012, 08:41:26 PM »
Turtle tall status.
« Reply #155 on: March 03, 2012, 10:29:37 PM »
It's only 6'8" and that's with the rear end riding 3" higher than it should.
These harnesses are awesome.
My transfer case is bad. When does anyone want to help swap a heavy ass 205?
« Reply #156 on: March 03, 2012, 10:42:15 PM »
bad?  whahuh?
« Reply #157 on: March 03, 2012, 10:42:35 PM »
are you doing it wrong? lol
« Reply #158 on: March 03, 2012, 10:50:31 PM »
There's is a bad bearing sound when the RPMs get up.
« Reply #159 on: March 03, 2012, 10:58:07 PM »
free spining it with no shafts hooked up i assume?
you have oil in it, sure the shift rods are in the correct position and fully in?
« Reply #160 on: March 03, 2012, 11:30:56 PM »
Yea, I checked the shift rails. And I changed the fluid. You can feel it in the case. I would rather just change it now, than wait and worry.
« Reply #161 on: March 04, 2012, 12:29:32 AM »
Good plan.
What belts did you get? Prp I see, details?
« Reply #162 on: March 06, 2012, 10:36:47 AM »
do you have the parts list for the front axle bearings?  did you replace the dust shelds on the lower king pin bearings?
id like to put all new junk in with the new Knuckles
« Reply #163 on: March 06, 2012, 10:47:22 AM »
i bet timken or BCA makes a complete kit..
« Reply #164 on: March 06, 2012, 12:12:02 PM »
I used to somewhere, it's not hard to find.
I got all my stuff from bronco graveyard.  I don't remember if they list real part numbers. I used to have a complete set of spares but I think some or most have been eaten up and not replaced.
