Author Topic: Amp draw  (Read 36411 times)
Re: Amp draw
« Reply #15 on: January 04, 2017, 05:24:58 PM »
Make sure your underhood light or done light are off!
You didn't say, what jeep? Glove box light stay on even when closed?
Although it sounds like you fixed it. It's called "surface charge" which usually get discharged after charging or running before the volt reading get stabilized.
Re: Amp draw
« Reply #16 on: January 04, 2017, 08:56:13 PM »
it's a TJ Rubicon. 04?
Re: Amp draw
« Reply #17 on: January 04, 2017, 09:01:57 PM »
sorry yes tj rubi 2006
Re: Amp draw
« Reply #18 on: January 04, 2017, 09:39:58 PM »
these are last night readings
This is after I push the range button
Now for the pictures today
And if I unhooked the leads and hook the negative back up and use the clamp it reads .45 to .56 a
 The battery is at 12.44v  now.
I think the jeep is telling me to drive it more.
Sent from my SAMSUNG-SM-G928A using Tapatalk
Re: Amp draw
« Reply #19 on: January 05, 2017, 08:46:58 AM »
Another 'must know' tech about checking battery.......
I am not sure about your TJ specifically but a lot of vehicles will have higher amp draw as soon as the battery is re-connected as it's computers/modules 'wake up' for a few minutes before they go to 'sleep' and the amp drops.
Re: Amp draw
« Reply #20 on: January 05, 2017, 09:12:51 AM »
ill have to try leaving meter on for a while then. thanks
