Author Topic: Troys new Truggy Chassis  (Read 96103 times)
Re: Troys new Truggy Chassis
« Reply #60 on: May 24, 2012, 08:53:48 PM »
« Reply #61 on: May 24, 2012, 10:53:55 PM »
hmmm,as much as i like the the look and cleanliness af an and steel braided line i dont think its in the budget,unless someone knows of a place with good prices
« Reply #62 on: May 25, 2012, 07:44:06 AM »
its all about fuel rated rubber!
« Reply #63 on: May 25, 2012, 08:58:40 AM »
http://www.summitracing.com/parts/SUM-220985
You want PTFE.
It only takes a bit of ethanol do damage rubber. Teflon is impervious to it.
« Reply #65 on: May 25, 2012, 11:41:33 AM »
Pretty interesting.
I think the new spec rubber (R9) is what it was all about when I was searching for replacement diesel line.
« Reply #66 on: May 25, 2012, 12:23:34 PM »
we use superthane for everything, its majic
« Reply #67 on: May 25, 2012, 12:24:49 PM »
That chart stuff is way over my head.you gotta understand I stack rocks for a living.
So all things aside what is my best affordable way to go for fuel line
« Reply #68 on: May 25, 2012, 12:28:14 PM »
I've been running low pressure rubber  gas for 4 years, I know it's not right but it's cheap
« Reply #69 on: May 25, 2012, 12:28:47 PM »
tell arie to get you 15' of MFI line (high pressure) and 15' of low pressure return line,  price was a 1/3 anywhere else i could find
advance wanted like 4.50$ a foot pauls price stupid
« Reply #70 on: May 25, 2012, 12:29:44 PM »
toyota system is probably 40-50psi, so that Erok, is dumb  on your part.
troys system is 14-16psi, so it probably would be fine
« Reply #71 on: May 25, 2012, 01:39:11 PM »
So how much is 30 feet of Fuel injection rated rubber line + clamps + TBI inlet / outlet fittings going to cost?
PTFE stuff is $2.80 / ft     fittings are $5 each.
« Last Edit: May 25, 2012, 01:41:57 PM by gif »
« Reply #72 on: May 25, 2012, 02:42:51 PM »
it was less than half that cost per foot and gator clamps are 89cents
« Reply #73 on: May 25, 2012, 03:24:10 PM »
Sold!
« Reply #74 on: May 25, 2012, 03:30:44 PM »
I should redo my supply
