Author Topic: Troys new Truggy Chassis  (Read 96205 times)
Re: Troys new Truggy Chassis
« Reply #285 on: September 19, 2014, 09:06:07 PM »
uhh, should i buy this, i know i dont need a 10" stroke but what difference would it make?
http://www.pscmotorsports.com/shop-by-brand/psc-mfg/full-hydraulic-cylinders/2-25-x-10-stroke-x-1-125-rod-de-cylinder.html
« Reply #286 on: September 22, 2014, 12:23:23 PM »
A ton more stress on the knuckles if the driver likes to hold the steering wheel at full lock.
« Reply #287 on: September 22, 2014, 01:09:36 PM »
get a 2.5x8
dont forget your need the clevis kit, and we run 4 clamps on all the cars
« Reply #288 on: September 22, 2014, 03:05:39 PM »
you would have 23614 lbs of torque at the king pin ( if i did my math right )
so, if your cylinder stroke is longer than the swing of the high steer arms your going to pop the top off your knuckles
« Reply #289 on: September 22, 2014, 03:54:52 PM »
alright, just making sure im not missing out on a killer deal
« Reply #290 on: September 22, 2014, 04:29:18 PM »
when are lbs a unit of torque   :o
i am sure troys PS pump might make 200 psi not 2000   8)
limiting spacers could be put on the ram, but seems like a lot of clap trap for the wrong size ram
« Reply #291 on: September 22, 2014, 08:06:39 PM »
woo hoo, picking these bad boys up for $300 for spare parts
https://rochester.craigslist.org/pts/4644409918.html
« Reply #292 on: September 23, 2014, 12:26:38 PM »
My buddy will buy the track bar bracket stuff off you if it is complete.  Let me know
« Reply #293 on: September 23, 2014, 06:46:02 PM »
Pile of axles acquired
1-d60 front
1-d60 rear
1-d70 rear
all 4:10 gears and full floater, track bar bracket and arm are there can bring to the next meeting
« Reply #294 on: September 30, 2014, 02:29:32 PM »
I've come to learn I suck at axle identifying, both rears are Sterling 10.25 ,stripped one threw it on my trailer along with 5 batteries, 12 rotors and some junk r. $100 back into buggy find.
No major issues at Rausch, throttle cable kinked and broke, replaced with a spare I thankfully had. Sat morning disconnected my Transfer case shifter and manually put it in 4low and this thing became a crawling machine
« Reply #295 on: September 30, 2014, 05:08:58 PM »
Nice
« Reply #296 on: October 12, 2014, 11:14:49 PM »
Got bored this weekend, 10.25 linked, shortened the wheelbase by 5" blah blah
Deceided to be a Guinea pig, ordered 2-2" foa's with resi's and dual rates
Mikemike, did you ever end up using the 10.25 stuff we traded? If you didn't ,wanna sell em back?
Went to the field and stream opening ran into some peeps and found a gimble cup holder for $8
« Reply #297 on: October 13, 2014, 08:06:49 AM »
Cup holder FTW!
« Reply #298 on: October 13, 2014, 08:45:45 AM »
Diff cover right? Still have, unused. Was there something else? Disk brake brackets maybe? They should still be there too
« Reply #299 on: October 13, 2014, 08:54:17 AM »
Just out of curiosity how much cheaper were the foas vs fox?
