Author Topic: XJ Heep 3.0  (Read 63093 times)
Re: XJ Heep 3.0
« Reply #180 on: June 30, 2018, 10:08:27 PM »
Today’s shakedown at Attica revealed a bad fuel pump. Initially we thought it was the dreaded fuel vapor lock so I removed the hood. This didn’t change anything.
Eventful trip back home as my dodge ran out of diesel.   ::)
I got it to act up again at home the filter/regulator felt warm. I put my spare fuel pump in it and it’s way quieter and the problem went away.
Round two tomorrow!  8)
Re: XJ Heep 3.0
« Reply #181 on: July 01, 2018, 05:38:34 PM »
Round two shake down today was successful.
The fuel pump restored power and no more random stumbling, stalling.
No more overheating even in this heat with A/C running. The cooling system repair/upgrade also fixed its hot idle oil pressure problem too.
Success
Re: XJ Heep 3.0
« Reply #182 on: August 08, 2018, 02:43:03 PM »
Ordered D50 4.56 ring & pinion from RockAuto for $76 plus shipping. Too good price to pass up even it’s the Dorman brand.
Re: XJ Heep 3.0
« Reply #183 on: August 12, 2018, 01:30:19 PM »
I think I beated on it more than what it owes me over the weekend.
More upgrades (& repairs) coming.
Re: XJ Heep 3.0
« Reply #184 on: August 12, 2018, 09:47:52 PM »
Glad it worked well other than the known (to attendees) damage! Nice to get a project out and about!!
Re: XJ Heep 3.0
« Reply #185 on: August 13, 2018, 03:43:09 PM »
Caliper removed and bled air out and capped off with some bolt and nut
Not looking to spend much on a new caliper. I’ll try new pistons and seals from RockAuto if the caliper is repairable (after I remove cracked pistons)
Re: XJ Heep 3.0
« Reply #186 on: August 13, 2018, 04:58:17 PM »
I don't think I've ever seen a caliper worth repairing rather than replacing money wise. Not a $35 caliper?
Re: XJ Heep 3.0
« Reply #187 on: August 13, 2018, 04:59:59 PM »
This.
Re: XJ Heep 3.0
« Reply #188 on: August 13, 2018, 05:11:52 PM »
You’re right. I was keep on thinking it’s like >$100/caliper (I just put new calipers on my dodge)
$25 each and no core charge on rockauto. I’ll get that one.
Re: XJ Heep 3.0
« Reply #189 on: August 14, 2018, 09:27:54 AM »
get a pair of them save yourself the hassel on the other side.
Re: XJ Heep 3.0
« Reply #190 on: August 14, 2018, 10:50:48 AM »
yup
Re: XJ Heep 3.0
« Reply #191 on: August 14, 2018, 04:52:55 PM »
Debating on what to do about the radiator.
1) take it out and bend/hammer it straight-er & apply JB welds if wherever it may need.
2) take to empire for an estimate (& repair if cheap)
Re: XJ Heep 3.0
« Reply #192 on: August 14, 2018, 04:55:29 PM »
A/C still fully functional, I’ll just try to straighten the condenser.
I’m gonna look for at least 15” by 36” of steel Expanded mesh to go in between condenser and grille.
Re: XJ Heep 3.0
« Reply #193 on: August 14, 2018, 05:24:23 PM »
If it’s not leaking now run it. Carry coarse ground black pepper which you always should anyway for small rad leaks
Re: XJ Heep 3.0
« Reply #194 on: August 14, 2018, 05:28:56 PM »
Surprisingly no leak. I’ll need to do something about it regardless. Mechanical fan is too close to it now.
I just threw a $89 offer to the eBay seller. I paid $89 for it in early June. It jumped to $135 now.
