Author Topic: All terrain forks  (Read 1095 times)
All terrain forks
« on: April 28, 2016, 08:58:26 AM »
I need to pick a vehicle pit of a field.
Can't be pulled..
Anybody have one of those fancy all terrain tractor things with forks?
I have fork extensions
Re: All terrain forks
« Reply #1 on: April 28, 2016, 09:04:59 AM »
Weight?
I don’t know if nick has forks for his skid steer but that’s the only equipment I can think of.
I think I saw rates around 300 for a half day for a 6k capacity telehandler. my trailer needs new decking before it could haul one of those. It would finish it off for sure.
jacel86
    • Tallmadge Tire
« Reply #2 on: April 28, 2016, 09:23:58 AM »
Location?
« Reply #3 on: April 28, 2016, 10:07:49 AM »
Penfield..
went to go pickup that old land rover on CL..
frame makes swiss cheese look solid and all the steel is just deteriorating around the aluminum..
I was going to grab it just for parts, and the patina aluminum..
just more work than its worth...
were talking cartoon type of extraction where the axles gets ripped out from the frame.. its literally melting into the ground...
« Reply #4 on: April 28, 2016, 10:27:39 AM »
Strap to both axles and pull the axles. Not going to put much stress on the mounts that way and won't hurt anything that matters. Probably less stress than picking it.
« Reply #5 on: April 28, 2016, 10:41:55 AM »
leaf springs aren't attached to frame other than load bearings rust..
looked at it for over and hour yesterday..  this things isn't being pulled.. needs to be picked..
« Reply #6 on: April 28, 2016, 10:43:08 AM »
I told him if its still there once my life settles down a bit ill strip it in his yard..
he was ok with that..
« Reply #7 on: May 04, 2016, 06:11:45 PM »
I could hook you up with my Contractor friend who has a 4x4 Lull Forklift. He has it transported from project to project by an excavation company. Might work out depending on his current and next job location.
Or another contractor friend who lives in Pendield. Owns a Bobcat.
« Reply #8 on: May 05, 2016, 09:18:54 AM »
sounds like a job for nick and chaddly
