Author Topic: WillBro  (Read 6602 times)
WillBro
« on: April 15, 2016, 09:02:43 AM »
sweet new bro in the delphi lot!
looks good stripped ready to go..
a little shop clean up tonight and start throwing some tube at it !
yessssss
« Last Edit: April 16, 2016, 11:57:51 PM by M4wdFab »
Re: WillBro
« Reply #1 on: April 15, 2016, 09:49:57 AM »
Nice
« Last Edit: April 16, 2016, 11:57:32 PM by M4wdFab »
Re: BillBro
« Reply #2 on: April 15, 2016, 11:58:13 AM »
looking good
Re: BillBro
« Reply #3 on: April 16, 2016, 12:45:41 AM »
40' of DOM in this thing tonight!
Re: BillBro
« Reply #4 on: April 16, 2016, 11:53:25 PM »
full day on this, another 60' of tube on it.  looks great.
cage in cap and bed 100% done, seat and column mounted.  front core cut up and under hood prepped for last two tubes.  rear shocks mounted, more cutting done.
should be good with a couple hours work tomorrow and ready for bill to finish up the plumbing and chassis maintenance.
Re: WillBro
« Reply #5 on: April 16, 2016, 11:57:18 PM »
Willbro*
Re: WillBro
« Reply #6 on: April 17, 2016, 08:55:32 AM »
Your an animal mike!
Re: WillBro
« Reply #7 on: April 17, 2016, 10:07:49 PM »
finished this up today, looks awesome.
front under hood tubes, coil bucket supports, radiator cross bar, harness tubes and tabs, bed sides mounted.
front shock buckets trimed for shocks, will cleaned up the wiring a bit so it runs again.
hit list for him to race day
remove windsheild
window net
front shocks install
radiator
brakes
2 radius arms
fuel cell and pump / lines
fire ext
fire suit
electric disco and battery mount
smaller tires
not a terrible list for a month away.
Re: WillBro
« Reply #8 on: April 18, 2016, 09:20:02 AM »
cage pics
Re: WillBro
« Reply #9 on: September 08, 2016, 01:16:20 AM »
front and rear bumpers done
front fender tube supports
radiator mesh
hood pins
needs a battery
new tires to grove
JWOK
  • Full Member
Re: WillBro
« Reply #10 on: September 08, 2016, 08:36:54 PM »
Damn!
Sent from my XT1254 using Tapatalk
Re: WillBro
« Reply #11 on: September 22, 2016, 08:41:40 AM »
this thing got a couple of good knocks from the two rolls.  front of frame bent 4-5" to the right, cab shifted around front clip and support hosed.
new hood and fenders mounted, lots of high lifting, porto raming, pounding.   looks like a truck again.
needs shock swap to fox, coolant hose repairs, and a little body work to go.
Re: WillBro
« Reply #12 on: September 22, 2016, 09:16:35 AM »
frame was worse than it looked, huh?
anything we should do to try and keep 'em straight in the future or just try not to roll hard and do the work if needed? I figure it'd take a decent amount of extra weight to brace it up and keep it straight and probably not be worth it
Re: WillBro
« Reply #13 on: September 22, 2016, 10:40:35 AM »
it was pretty bad.
front cross member and radiator support not tied in great.
was a pretty hard roll
Re: WillBro
« Reply #14 on: September 22, 2016, 11:11:33 AM »
I bet you can build one of these thing's and show up to a race ready to sell
