Author Topic: Trim ring  (Read 851 times)
Trim ring
« on: February 22, 2016, 03:57:18 PM »
where can I get one made?
team aussie has a laser table cutter thingy right?
Re: Trim ring
« Reply #1 on: February 22, 2016, 10:35:10 PM »
give me a pattern, i can cut out a few from 1/8" and you wouldnt know they werent lazer cut with 10min of my work
Re: Trim ring
« Reply #2 on: February 23, 2016, 10:06:04 AM »
Took 2 beers but I think I came up with the reasonable way to approach this..
the Aqualu tub has the same tans angle as a factory tub... factory trans cover should work with a little massaging...
Tried to see how to make it fit with as little cuts as possible.. my opening seems to be 2" longer and 2" wider than factory..  Need to check height again, but I think Im good..
Smike is this up your alley?  I have at least the one extra in the picture.. might have a couple more in the warehouse...  would make it easy to use a universal boot at this point..
Re: Trim ring
« Reply #3 on: February 23, 2016, 10:07:24 AM »
if I had a band saw and another beer I would have gotten a little carried away.. just was afraid to make too many cuts with a sharpie and a jig saw :o
