Author Topic: Big Block Bowtie  (Read 3467 times)
Big Block Bowtie
« on: February 12, 2016, 07:41:48 PM »
New tow rig from Texas
8.1
Allison
What a boat
Excited to a avoid high mile diesel issues
Re: Big Block Bowtie
« Reply #1 on: February 12, 2016, 08:17:26 PM »
pretty
enjoy the gas prices.  hope it has a 39 gal tank
« Reply #2 on: February 12, 2016, 08:55:05 PM »
Pilfering the BBB moniker?  :P
« Reply #3 on: March 14, 2016, 11:16:37 PM »
No start issue.
First instance was a few weeks ago. Normal start then  stalled after running >1 second. Cranked and wouldn't start. Let sit 10 seconds and fired up.
Second same as first.
Tonight same issue. But won't go. All times it's done this before it throws a CEL for MAF and p1514 which Internet says is "throttle performance issue". Now just throwing p1514. I cleaned throttle body, checked TPS plugs. Cleaned MAF and checked plug. MAF appears to be new and aftermarket.
Internet says one of:
Broken wires
Bad plug connection
Faulty PCM
« Reply #4 on: March 14, 2016, 11:32:11 PM »
big boo!
« Reply #5 on: March 15, 2016, 08:02:22 AM »
Check fuel pump too
« Reply #6 on: March 15, 2016, 08:12:10 AM »
I can hear the fuel pump running.
smells very strong of fuel after cranking. no visible leaks. seems like computer is giving no spark.
possibly crank position sensor. sounds like they like to break off in the block. great.
« Reply #7 on: March 15, 2016, 09:24:59 AM »
Even if you can hear the pump, it doesn't necessarily mean that it is providing the required fuel.  But likely not the issue with other symptoms you mentioned.
« Reply #8 on: March 15, 2016, 11:16:18 AM »
Hmmmmm
Hahaha someone has to bring it up
« Reply #9 on: March 15, 2016, 12:36:53 PM »
I'm not sure about 8.1 but at least on 4.3 it'll run with the maf unplugged (defaults to speed density). I had to on my old ZR-2 when it's maf got coated in mud after a mudding.
If it have sparks, it may be injecting too much fuel/too rich and won't start.
It have camshaft position sensor? If so, you can try to unplug crank shaft position sensor and try to start it. It'll take longer cranking though. GM did a nice job and made it to run without some sensors for in case some of them going bad although it can get finicky if some of them still somewhat working and PCM try to use its data and cause problems.
« Reply #10 on: March 15, 2016, 01:16:59 PM »
started right up at lunch and drove it home.
« Reply #11 on: November 15, 2016, 12:54:35 PM »
sent.
in the market to buy asap.
jeep
truck
« Reply #12 on: November 15, 2016, 12:55:17 PM »
I've got a friend with an F100 or something for sale....
why'd it go?
« Reply #13 on: November 15, 2016, 01:27:42 PM »
too big for the new place
MPG sucks
needed some things
sold for profit
probably replace with a 6.0 2500HD ECSB
