Author Topic: front 14 bolt build  (Read 2669 times)
front 14 bolt build
« on: September 02, 2015, 09:45:43 PM »
its time with only one more 5.38 gear set on the shelf.  not going to buy another 60 set.  no 70 set available so 14 time.
i have looked at drop out options. cost is high.  i dont see a need for anything more than a stock center section.
Hopping Cora can broach a couple 14's with 35spline 60 holes and keep the RCVs for now.
spin up a set of seal boars, new solid C's, swap everything and truss up an axle with tabs.
for 500$ and a weekend i should be in.
Re: front 14 bolt build
« Reply #1 on: September 02, 2015, 09:48:05 PM »
« Reply #2 on: September 03, 2015, 09:51:40 AM »
Running backwards, I wonder if you will have better luck than with 60 stuff or not.
I think pinion offset from axle centerline is different, you're not too tight on clearance up front though, that should be fine.
I just wonder how much of an upgrade it really will be. Shame no 70 sets around, I really think that would be a better option.
« Reply #3 on: September 03, 2015, 10:39:43 AM »
no 70 set available
what do you mean?
no gears available?
« Reply #4 on: September 03, 2015, 12:52:19 PM »
5.38 gears are not an option for D70.  D70 spools are also about 600$
My 14 running backwards in the rear could give a crap about anything i have done to it.  its was run in 571 for 3 years before 572 also.
« Reply #5 on: September 03, 2015, 02:52:10 PM »
fair enough!
