Author Topic: tires for my cummins  (Read 1213 times)
« on: August 31, 2015, 10:12:51 AM »
looking for tires or wheels and tries for my cummins
preferably used
285s ish
anyone have anything lying around?
Re: tires for my cummins
« Reply #1 on: August 31, 2015, 07:41:24 PM »
Related, what do you recommend for ball joints?
« Reply #2 on: August 31, 2015, 08:00:58 PM »
I have stuck to MOOG chassis components when I can - but that's based on many many years ago info. These days I trust Arie's judgement :)
« Reply #3 on: August 31, 2015, 09:25:18 PM »
whatever arie says.
borrow or bring the truck to my shop to use the M4 ball joint press.  will save you 4 hours of swearing and pounding on a C clamp style garbage press.
« Reply #4 on: September 01, 2015, 07:57:14 AM »
I shall default to the recommendation of the parts master.
I will definitely take you up on the M4 ball joint press. thanks
« Reply #5 on: October 07, 2015, 09:51:11 PM »
Looking for (2) 285/70r17 load range E with good tread
« Reply #6 on: October 08, 2015, 09:06:09 AM »
gona rock H2's noice!
« Reply #7 on: October 26, 2015, 02:33:37 PM »
The guy I just didn't buy snows from has 4 265/75R 17 no – name load range E for 100 bucks if you're interested.
« Reply #8 on: October 27, 2015, 08:19:06 AM »
I am potentially.
Can you send his number my way?
thanks
« Reply #9 on: January 28, 2016, 03:59:32 PM »
I used XRF ball joints in my truck but one got a little loose after 60k-ish miles. I replaced them with MOOG from AAP so that way I can get them warranted and replaced on my truck in a day. My HF ball joint press with HF's ball joint press adapter set work perfectly.
