Author Topic: wonder 4.0  (Read 22646 times)
Re: wonder 4.0
« Reply #15 on: August 19, 2015, 09:01:20 AM »
i have new fronts installed i had that are good.  need the rears, 3-4" lift over stock id guess.  they are eye lower, barpin/eye uppers.  i can order from summit if you cant get.
Next i need:
exhaust down pipe
exhaust tail pipe
left and right rear wheel cylinders  (8.25"  with 9" brakes)
left and right rear e brake cables
the exhaust manifold is F'd on this thing someone spooged this grey stuff all over it, its cracked, hacked flange clamps, no idea how to start.... bah
should be it until i read the codes!
Re: wonder 4.0
« Reply #16 on: August 19, 2015, 09:25:21 AM »
I still have a (repaired) 1998(?) TJ manifold hanging in my shop, if it will work. Would like to see it put to use before I get tired of looking at it and scrap it.
Re: wonder 4.0
« Reply #17 on: August 19, 2015, 09:34:23 AM »
really hoping i can just clean it up and make it work.  i have another one on and engine sitting in the shop too.
Re: wonder 4.0
« Reply #18 on: August 19, 2015, 09:53:29 AM »
Dorman makes a manifold for it... 2  in stock
Re: wonder 4.0
« Reply #19 on: August 19, 2015, 10:20:38 AM »
ill let it scream before i change a header buried in and engine bay on a 248K motor lol
Re: wonder 4.0
« Reply #20 on: August 19, 2015, 10:42:48 PM »
picked up shocks tonight
slid little shoes on and put aside for some Rover work!
Re: wonder 4.0
« Reply #21 on: August 23, 2015, 08:28:56 PM »
rear shocks installed
most of exhaust torched out
gas tank straps reaplaced
trim double sided tape gunk, and black over spray removed
masked and rebedlined two tone black
mounted 35 scrs on another set of mustang wheels
Re: wonder 4.0
« Reply #22 on: August 23, 2015, 09:31:22 PM »
ordered an adjustable track bar and new track bar bracket.  bah
Re: wonder 4.0
« Reply #23 on: October 13, 2015, 10:58:37 AM »
full exhaust installed last night.  had to do some interesting things to mate to the abortion of spooge on the header collector.
Adjustable track bar and new drop track bar bracket installed.  actually got the bolts out and reused them.  couldn't get any of the junkyard ones to budge.
Re: wonder 4.0
« Reply #24 on: October 15, 2015, 01:17:01 PM »
extended sway bar links / swaybar installed
new oil pressure sensor installed
Re: wonder 4.0
« Reply #25 on: October 18, 2015, 08:10:09 PM »
heat doors and a radio was nice today on the trail!
sweet machine.  needs rear brakes and full brake bleed, and some leaks and power steering whine addressed.  otherwise wonder status
Re: wonder 4.0
« Reply #26 on: October 18, 2015, 09:02:24 PM »
Sweet
Re: wonder 4.0
« Reply #27 on: November 01, 2015, 07:37:48 PM »
rear axle work done:
hardlines
wheel cylinders
brake shoes
hardware kit
drums
ebrake cables
adjusted front track bar
front end trans leaks and steering whine up next.
Re: wonder 4.0
« Reply #28 on: November 02, 2015, 09:02:24 AM »
cleaned everything up front.  not sure still where leaks coming from.
CEL's down to rear O2 and Evap.  Purge soloniod measures 33ohms.   spec is 40-80ohms   :o
Re: wonder 4.0
« Reply #29 on: November 03, 2015, 10:29:42 AM »
body work and paint done on passenger door last night
driver rear 1/4 up next.
