Author Topic: wonder 4.0  (Read 22644 times)
wonder 4.0
« on: August 12, 2015, 11:44:01 PM »
wonder 4.0
delivered to M4 for 700$
disapointed tires are miss matched and pretty junk, but over all still a good deal.  lots of hacks.
tonight on the lift, i got 3 out of 4 fenders cut out tucked, and trimed, new front lift coils and shocks before a test drive around the block.
shifts and goes ok, something is slamming like hell in the rear on the littlest bumps  its got to be broken sezied rear shocks or the tank flapping around.  interior pretty good, most of the body rot will be cut off with the normal xj trims
driving to work tomorrow!
Re: wonder 4.0
« Reply #1 on: August 13, 2015, 08:26:46 AM »
pics?
Re: wonder 4.0
« Reply #2 on: August 13, 2015, 09:05:58 AM »
Sweet ride that im regretting not buying
Re: wonder 4.0
« Reply #3 on: August 13, 2015, 09:24:49 AM »
oh boy...
Re: wonder 4.0
« Reply #4 on: August 13, 2015, 12:31:28 PM »
triming, new coils / shocks up front.
Re: wonder 4.0
« Reply #5 on: August 15, 2015, 07:18:22 PM »
reaplaced rear brakes hardline
finished fender trims
rear slamming is 3" lift leafs with stock shocks  :o
Re: wonder 4.0
« Reply #6 on: August 17, 2015, 07:51:03 AM »
Nice!
Re: wonder 4.0
« Reply #7 on: August 18, 2015, 10:26:16 AM »
front end tore up and 4 ball joints removed.
took less than 4 minutes to remove crusty ass seized in ball joints.  i love this tool every time i get to use it.
Re: wonder 4.0
« Reply #8 on: August 18, 2015, 01:50:02 PM »
I should bring my 3500 over and use that instead of trying to do them by hand! I've been dreading that.
Re: wonder 4.0
« Reply #9 on: August 18, 2015, 02:09:53 PM »
have a party with Matt, his needs it too this week
it literally will bring joy to your face.  it took me two days to do my 24valve with the shit C tools, they suck.
Re: wonder 4.0
« Reply #10 on: August 18, 2015, 02:13:08 PM »
for the top ball joints, do you find that it will push straight if you leave the tapered shank on it? or do you chop that off and use a piece of toob?
Re: wonder 4.0
« Reply #11 on: August 18, 2015, 02:15:52 PM »
for removal?  i cut the taper off, then stick in a flange nut that pushes on the body
Re: wonder 4.0
« Reply #12 on: August 18, 2015, 06:31:00 PM »
just sold the tires and wheels off this unit for 300$  win
Re: wonder 4.0
« Reply #13 on: August 18, 2015, 11:06:36 PM »
ball joints, unit bearings, ujoints and front axle back together
exhaust, rear brakes and front tie rods next , then fluid leaks and CEL investigation.
what a wonder!
gota mount up another set of SCRs  ordered wheel spacers, still need rear shocks.
Re: wonder 4.0
« Reply #14 on: August 19, 2015, 08:17:18 AM »
want to get a set of rancho?
I can order for you.. I think Monroe even makes a lifted variety
