Author Topic: 12v Injectors  (Read 1452 times)
12v Injectors
« on: July 01, 2015, 08:52:54 AM »
I want to buy new injectors for my truck. I bought some aftermarket injectors before they they SUCKED. I spent hours trying to get them to fit in the holes, gouged up the alignment slot and eventually just put stock back in.
I'm looking for stock Bosch injector bodies that have 5x12 SAC nozzles. I cant find them anywhere. I could install the 5x12 nozzles on my current injectors, but they have 450k on them so figure new wouldn't be bad.
Re: 12v Injectors
« Reply #1 on: July 01, 2015, 09:29:14 AM »
DAP used to list a Bosch body with aftermarket nozzles, but its not there anymore.
Re: 12v Injectors
« Reply #2 on: July 01, 2015, 09:37:08 AM »
Damn, that was going to be my suggestion.
Get your bodies rebuilt, with fresh 5x12 nozzles on them? pop off injectors are easy to set and shim, as long as they don't leak that's all that really matters if I understand correctly.
Re: 12v Injectors
« Reply #3 on: July 01, 2015, 10:33:18 AM »
I still have the aftermarket injectors with 5x12 nozzles. I'm tempted to just install the nozzles on the stock injectors and rock it.
Or see if B&D can pop test them and flow mach.
I couldn't believe how shitty the aftermarket bodies were. Absolute garbage.
Re: 12v Injectors
« Reply #4 on: July 01, 2015, 11:17:34 AM »
check out GB injectors...
we stock them and have a great reputation...
Re: 12v Injectors
« Reply #5 on: July 01, 2015, 11:18:39 AM »
Re: 12v Injectors
« Reply #6 on: July 01, 2015, 11:22:17 AM »
my ford guy was very impressed with the injectors I bought.. he said they looked just like the OEM ones they use at the dealership.
Re: 12v Injectors
« Reply #7 on: July 01, 2015, 11:24:35 AM »
ok that has potential.
PN for new is 611-105, reman 711-105.
price?
Re: 12v Injectors
« Reply #8 on: July 01, 2015, 01:22:52 PM »
new 75ea
reman 55ea... need cores
Re: 12v Injectors
« Reply #9 on: July 01, 2015, 05:48:44 PM »
The new ones are Bosch or they're their own units?
215hp too? I may be interested sometime later this summer.
Re: 12v Injectors
« Reply #10 on: July 02, 2015, 09:07:05 AM »
check the website..
you guys know more about diesel than I do
the New ones I can ask the rep about..
Re: 12v Injectors
« Reply #11 on: July 02, 2015, 12:22:36 PM »
They are aftermarket, not Bosch. HP number given to injectors is silly to me. So much is dependent on other mods.
I am leery given my last experience with aftermarket but may try. Will probably pull and clean mine first.
