Author Topic: Free truck parts. Drive shafts, t-case, D60 parts & more.  (Read 3613 times)
Dodge Ram 2500 D70 SRW 3.55 gears, tight limited slip diff. Worked fine when pulled but I'm not sure on its ring & pinion condition. It had trashed carrier bearings which I caught quickly and fixed that but I just replaced the bearings with old shims back in. It went back in the housing very tight (dead blow pounding to get it in). I drove it like that for more than 3k miles before I swapped the D80 in.
Dodge Ram 2500 np241DLD. Worked fine when pulled. I replaced it when I upgraded to NP271D. I also am not sure on its condition. The oil get black quick and had gunks on bottom by the drain oil. The chain can be felt loose through the oil fill. Although it never gave me any problem, regardless.
92-97 F350 D60 c to c housing with factory 3.55 gears still in it.
2x of 2nd gen ram 2500 2-pc rear drive shafts.
1x of 2003 ram 2500 rear drive shafts
D80 factory limited slip carrier. Unknown condition. I put a TruTrac limited slip carrier in my D80 before I put it in. Big & heavy!
1 barrel hand crank pump.
I'll list more items as I find them. I'm currently moving out of my house and I don't want to drag stuff around that I don't want to keep.
I can deliver if either local or somewhere along the way to my work in Rome, NY.
Text me for pictures! 6308640378
Re: Free truck parts. Drive shafts, t-case, D60 parts & more.
« Reply #1 on: June 21, 2015, 12:03:44 PM »
2nd gen ram rear driveshafts have 1410 yokes which you may want for your driveshaft! I have 2 new Spicer 5-1410X u-joints for anyone who may need them.
3rd gen ram rear drive shaft use 1485 joints (but the betterer 1480 joint still can be used). It still have the flange mount for the axle (bolts to the flange to the rear axle, not by straps or u-bolts).
Please take them as I'll hate to just scrap them if someone may need them.
« Reply #2 on: June 21, 2015, 01:02:25 PM »
Pick me!
« Reply #3 on: June 21, 2015, 01:08:54 PM »
I’ll take any drive shafts & yokes, and the 3.55 geared ford front. Can just put in the trailer when you return...
Thanks!
« Reply #4 on: June 22, 2015, 12:18:20 PM »
ill take the case if its pass side front output style
« Last Edit: June 22, 2015, 12:22:57 PM by gif »
« Reply #5 on: June 22, 2015, 12:46:06 PM »
case is a newer dodge, it'll be driver output.
wnyjpgy
« Reply #6 on: June 30, 2015, 12:57:53 PM »
Is the D80 carrier still available, mine just started getting clunky on tight turns.
Going to pull the cover tonight, and take a look, but spare parts would be helpful.
« Reply #7 on: June 30, 2015, 01:13:54 PM »
I have it. I don't need it, just trying to turn some of this stuff into cash for Brett, since he got booted from his lease.
Let me know if you need it.
« Reply #8 on: June 30, 2015, 02:19:15 PM »
would love to know more about this!!!!!
im sure there is a story
wnyjpgy
« Reply #9 on: June 30, 2015, 02:24:51 PM »
Where's it located?
Depending on my inspection tonight after the cover comes off, I might be interested in heading your way tomorrow to grab it. I have to leave for oklahoma city thursday night, so I'm kinda in a situation..LOL...
Shoot me your phone number, and what you need for it in a pm.
« Reply #10 on: June 30, 2015, 02:28:49 PM »
josh i have D80 setup bearings if you need to borrow
« Reply #11 on: June 30, 2015, 02:39:51 PM »
lease was up and month to month. house was on the market and pending sale  then and turned into a "get your stuff out in 10 days we are closing"
or something like that.
Where's it located?
PM inbound.
« Reply #12 on: June 30, 2015, 02:42:48 PM »
NYS requires 30 day notice
wnyjpgy
« Reply #13 on: June 30, 2015, 02:57:37 PM »
Thanks Mike.
I'll keep you guys posted. I spoke with Matt in Darien, he has a few on the shelf as well.
PM Received.
« Reply #14 on: July 01, 2015, 02:51:02 AM »
He did gave me the notice. But there's more to it which made me to move my feet really quick.   :o
