Author Topic: 2006 CHEVROLET EXPRESS 3500 V8-364 6.0L  (Read 1856 times)
« on: April 17, 2015, 09:37:05 AM »
in a van down by the Potomac river..
Auto trans.. 350K ish.. maybe more
Re: 2006 CHEVROLET EXPRESS 3500 V8-364 6.0L
« Reply #1 on: April 17, 2015, 09:41:11 AM »
"Well whoopty frikkin doooo!" Lol
« Reply #2 on: April 17, 2015, 10:05:41 AM »
Lotsa miles. Maybe interested. Depends  on compression numbers on mine and why you're retiring this. I gained smoke in California, haven't checked it out yet.
« Reply #3 on: April 17, 2015, 10:22:38 AM »
trans blew..
needs front end and suspension work work
« Reply #4 on: April 17, 2015, 01:39:50 PM »
Boo no trans... Hmm.
« Reply #5 on: April 18, 2015, 05:37:49 PM »
your trans would bolt to it.  ECM change and flash needed of course.
4l whatever trans wouldnt fit without engine movement or case movement/shafts
van motor has correct pump for steering, if it was in service, part out probably break even for 6-800$
no trans is sad for my interest.
« Reply #6 on: April 19, 2015, 01:29:11 PM »
4x4 od trans with a married case is probably best for me if I'm changing anything significantly.
« Reply #7 on: April 19, 2015, 06:41:43 PM »
which i would not recommend a mated case.
im really curious as the whats making your smoke.  that motor was well rapped by us and def held up great.  i dont recal you doing any worse to it last year.
got to be a valve or ring?  id be throwing a cam heads pistons and new flash at that thing.  much more life left than my motor id hope
« Reply #8 on: April 19, 2015, 07:25:01 PM »
Not sure about more life than yours. How many times north of 250 degrees on each? How many zero oil pressure shutdowns due to noise rather than gauge? I think this one has been raped a fair bit harder even if it was younger to begin with.
Probably will get raced as-is without any diagnostics with The Sickness presenting. MJ next weekend.
