Author Topic: GM 14 Bolt Prototype  (Read 33207 times)
CJ
« on: April 14, 2015, 06:32:03 PM »
Looking for volunteers to test our GM 14 bolt prototypes.
If you're welded, let me know. Our design (and our competitors) re-use the stock axle gear. I can supply new ones. We re-use the cross pin as well.
Let me know, fresh form heat treat. Would like the lockers to see some street time as well.
Re: GM 14 Bolt Prototype
« Reply #1 on: April 14, 2015, 07:56:51 PM »
10.5" or 9.5"?
(when I had my Yukon with 14 bolt swap years ago, I couldnt find any decent lockers for it at the 9.5" version)
« Reply #2 on: April 15, 2015, 09:32:16 AM »
I think all three u4 cars are running full spools now, not sure what other rigs are running 14s. Gif and Jeff maybe? I think all the tow rigs are AAM 11.5s not 10.5" 14 bolts too.
Callelle
« Reply #3 on: April 15, 2015, 09:40:56 AM »
I have a 14 bolt in my 2500 I could donate use for. It's mostly street driven, but I do enough driving it through the field for work on the farm that it may work well enough for testing.
« Last Edit: April 15, 2015, 09:47:39 AM by Callelle »
« Reply #4 on: April 15, 2015, 10:04:35 AM »
I've got one, welded. I can try to get a little street time on it, but it will be minimal haha
orange anchor
« Reply #5 on: April 15, 2015, 10:32:37 AM »
Gif and I are both running full-floater 14 bolt welded rears.  Gif is running 14-bolt in Duramax also.  (9.5" are considered semi-floaters and not the same animal)
« Reply #6 on: April 15, 2015, 11:41:10 AM »
Oh, I figured Gif's tow rig was AAM 11.5 same as my 3500 Dodge.
CJ
« Reply #7 on: April 15, 2015, 02:01:17 PM »
After some discussion with our engineer, I think we will test offroad applications first.
I'll call Jeff.
Harry, PM me your address if you are interested. I can send you a new cross pin and thrust washers if you need them, let me know.
