Author Topic: MMTR Brolite  (Read 94835 times)
Re: MMTR Brolite
« Reply #180 on: May 16, 2016, 02:49:58 PM »
More rebound in back is the most important change - not sure I'd add compression to get it though.
Take a look at the way the back bounces on landing in that video the instant before I catch the berm.
didn't double check front bumps
Re: MMTR Brolite
« Reply #181 on: May 16, 2016, 04:04:06 PM »
If you guys didn't know or if it even helps but explorer rear leafs are direct bolt in upgrade from 3 to 4 leafs
Re: MMTR Brolite
« Reply #182 on: May 16, 2016, 04:08:19 PM »
I need less rate and more travel, not less. I'd consider dropping the bottom leaf or even going to a main leaf only and adding a traction bar (should be legal: rules state stock main leaf, all else is open)
Re: MMTR Brolite
« Reply #183 on: May 17, 2016, 10:37:42 AM »
welding on two new bolts to lower the vertical component in the rear will do what you just asked for - in the right direction less compression, less rebound
did you look to see if the front bump stops were still present and happy?
driver side looks perfect, passenger side still 2/3 attached.
Re: MMTR Brolite
« Reply #184 on: May 17, 2016, 10:47:09 AM »
looked like on millers and a few other cars, standard procedure was to take a cut off wheel and remove the two halves of the bottom leaf without unbolting anything
Re: MMTR Brolite
« Reply #185 on: May 17, 2016, 12:01:46 PM »
makes sense.
only suspension thing I may do is swap out those front bump stops, not touching anything else unless I discover it falling off.
Re: MMTR Brolite
« Reply #186 on: May 17, 2016, 12:10:12 PM »
No worry about axle wrap?
Re: MMTR Brolite
« Reply #187 on: May 17, 2016, 12:59:33 PM »
so much wrap with the 2.3 power house to worry about!
Re: MMTR Brolite
« Reply #188 on: May 18, 2016, 12:11:49 PM »
I have a set of explorer spring if you guys want to try them at some point.
Re: MMTR Brolite
« Reply #189 on: May 18, 2016, 12:29:30 PM »
Matt if they don't want them I'll take them, looking for some for the ranger
Re: MMTR Brolite
« Reply #190 on: May 18, 2016, 01:00:27 PM »
All yours, Troy, I think.
Re: MMTR Brolite
« Reply #191 on: May 20, 2016, 08:12:34 AM »
FYI- i for the life of me could not get the mast line out of the slave- its easy to get to, just would not pop out.  the line is hard thick wall plastic 3/8 tube that swedge lock compression fittings work find on :)
Ditto. Hours wasted trying.
Re: MMTR Brolite
« Reply #192 on: May 20, 2016, 05:51:51 PM »
Fucker won’t bleed out. Got some strange white spooge out of it.
Hopefully Spencer will share an epiphany when he arrives.
All goddamn day to load shit up on 571 to brig over, load drive and park a trailer, and R&R a trans and clutch.
I’d starve to death working book rate.
Re: MMTR Brolite
« Reply #193 on: May 20, 2016, 06:00:29 PM »
clutch slave has to be bled on the bench upsidown, it cant be done in the truck
Re: MMTR Brolite
« Reply #194 on: May 20, 2016, 06:01:02 PM »
I thought the master had to be bench bled not the slave
