Author Topic: Tonys White Diamond Z71  (Read 11256 times)
Re: Tonys White Diamond Z71
« Reply #30 on: March 05, 2015, 06:00:23 PM »
89 octane fuel?
tony
  • Come and take it
« Reply #31 on: March 05, 2015, 06:18:12 PM »
87.. Says I can use e85 not sure if that will be better
« Reply #32 on: March 05, 2015, 07:15:09 PM »
it will be worse
my truck is supposed to run on e85 and millage sucked
« Reply #33 on: March 05, 2015, 07:51:39 PM »
Ethanol contains fewer Btu/gallon. #science
« Reply #34 on: March 06, 2015, 07:50:03 AM »
Give the 93 a try.
Always better milage in my experience.
« Reply #35 on: March 06, 2015, 08:04:07 AM »
But almost never fewer $/mi, if that's your goal. E85 can potentially win on that front with all its fucking subsidies. I don't think its THAT cheap here in NY though.
« Reply #36 on: March 06, 2015, 08:09:22 AM »
my coworker has a 2014 f150 with the 5.0. 18.5mpg on 89. 12mpg on E85. F that
« Reply #37 on: March 06, 2015, 08:10:35 AM »
Tony,
This is the brake controller I was talking bout. IMO, the only one to get. It should be plug and play.
http://www.amazon.com/Tekonsha-90195-Electronic-Brake-Control/dp/B000P17NXQ
tony
  • Come and take it
« Reply #38 on: March 06, 2015, 10:56:37 AM »
Thanks.   Keep it in mind when I buy a trailer
« Reply #39 on: March 06, 2015, 11:16:52 AM »
Tony,
That's the same brake controller I have in my Sierra. Fantastic!  Don't get anything else other than the P3.
BTW it wasnt plug n play for me. I had to splice wires together, but it was such an easy job. The wiring harness was under the dash.
« Reply #40 on: March 06, 2015, 05:17:37 PM »
...and under the hood by the fuse box.  Easy.
'07+ GM made you work for it.
tony
  • Come and take it
« Reply #41 on: March 10, 2015, 11:05:43 PM »
CAI installed .. 2 mpg more from Rochester to buffalo and back...
« Reply #42 on: March 11, 2015, 07:44:02 AM »
Hand calculated? Lieometer isn't worth anything for that.
