Author Topic: 1948 Chevy Loadmaster 2-ton  (Read 42286 times)
Re: 1948 Chevy Loadmaster 2-ton
« Reply #75 on: August 11, 2015, 04:18:21 PM »
sMike was right.  Located the split, clamped as best I could and welded the split.  Then put a 1" bead on either side of the split, 1" bead at the other four "corners".  Ground tooth valley clear.  Realized that part of the bendix would want to occupy the same space as the weld beads.  Grabbed the grinder and trimmed the top of the beads.  Installed old bendix in new starter, installed starter, applied power and crank rotated!  Reinstalled spark plugs and tried cranking again; still OK.  Bendix still bangs on the split space but I'll get over it until it breaks.
Installed two missing plug wires and attempted to fire; no joy.  Checked spark; none.  Checked coil terminal; no juice.  Vetted ignition switch and it works opposite of every other switch I've had.  Rechecked coil terminal; good.  Replaced all plug wires and rechecked spark; good.  Got my nearly empty can of ether and went to work.  The rest of the can yielded a cloud of blue smoke and a couple of pops of exhaust!
Promising!
jacel861
  • Full Member
« Reply #76 on: August 11, 2015, 05:26:29 PM »
Bringing old iron back to life...awesome :-)
« Reply #77 on: August 11, 2015, 07:42:43 PM »
sMike was right.
You act like that is a surprise to you.
« Reply #78 on: August 11, 2015, 09:51:31 PM »
yesssss make it fire.  so fun!
« Reply #79 on: August 11, 2015, 10:34:32 PM »
Awesome.  Need a video when you get it running...
« Reply #80 on: August 12, 2015, 12:15:54 PM »
After numerous trips to the DMV and mail exchanges with NE owner, this thing is officially a NY truck.
Let the rusting begin...
« Reply #81 on: August 12, 2015, 01:59:28 PM »
wooo!
« Reply #82 on: August 12, 2015, 02:08:26 PM »
even when everything I'm trying to do is 100% kosher I always get anxiety at the DMV..
« Reply #83 on: August 12, 2015, 02:25:19 PM »
it takes 30 min of research to be smarter than anyone in that building- just need to go in prepared
« Reply #84 on: August 12, 2015, 05:08:52 PM »
After getting Gus successfully titled, I don't think I'll have much angst in future DMV visits :)
« Reply #85 on: August 12, 2015, 05:20:20 PM »
« Reply #86 on: August 12, 2015, 05:21:47 PM »
Ooooh!
« Reply #87 on: August 12, 2015, 05:26:21 PM »
« Reply #88 on: August 12, 2015, 05:48:36 PM »
Sweet old iron
« Reply #89 on: August 12, 2015, 09:01:12 PM »
Sooo cool.
