Author Topic: 1948 Chevy Loadmaster 2-ton  (Read 42311 times)
Re: 1948 Chevy Loadmaster 2-ton
« Reply #60 on: July 18, 2015, 03:47:46 PM »
Got plugs, wires, points, condenser, cap, rotor, and battery from Arie.
Hooked up battery.  Heater fan spun.  Fuel gauge clicked.  No fire or smoke.  Good.
Mashed the starter foot switch.  Starter spun but motor didn't crank...
Removed starter.  Motor looks decent, shaft good, starter drive likely bad...
« Reply #61 on: July 18, 2015, 08:01:17 PM »
Positive or negative ground?
« Reply #62 on: July 18, 2015, 08:11:41 PM »
Chevys had negative ground, GMCs had positive ground.
« Reply #63 on: July 18, 2015, 09:47:34 PM »
Could it be that the starter is spinning the wrong direction? Did you try bench testing with positive ground?
« Reply #64 on: July 19, 2015, 08:42:51 AM »
Bench-tested correct rotation.  When in the truck, there was sound like cranking and some kind of "hitch" that it would push through.  The bendix is likely dirty/rusty enough not to engage fully.
tony
  • Come and take it
« Reply #65 on: July 19, 2015, 10:12:17 PM »
Sent from my SM-N900V using Tapatalk
« Reply #66 on: July 20, 2015, 09:43:34 AM »
bench tested clockwise rotation and bendix spins out on the bench?
« Reply #68 on: July 26, 2015, 11:37:58 AM »
looks good!
« Reply #69 on: July 26, 2015, 02:38:32 PM »
Kinda looks like a winner. And perfect.
Wonder mileage and history
« Reply #70 on: August 10, 2015, 04:52:28 PM »
While installing new starter, observed that flywheel ring gear was not seated/spaced uniformly on the flywheel.  Dag-gum (ranch vernacular) thing is spinning on the flywheel...
« Reply #71 on: August 10, 2015, 04:58:20 PM »
oh noes!
field fix would be to rotate assy to fully seat and give it 6-8 decent tack welds....  probably asking for a crack though
« Reply #72 on: August 10, 2015, 05:10:21 PM »
What do I have to lose?  Likely already cracked somewhere.
« Reply #73 on: August 10, 2015, 05:33:00 PM »
guarantee its cracked and is a C instead of a ring now.
if this is verified, got pull it and change.... or else you will just hose the starter again even if you did get a few welds on it in the right place.
the press on those things is crazy i did my CJ what a job
« Reply #74 on: August 10, 2015, 09:49:25 PM »
i did freezer / oven    dropped right on...
